[SCM] PostGIS branch master updated. 3.4.0rc1-792-gd8bbc4f97
Wed Nov 22 13:13:22 PST 2023
the project "PostGIS".
       via  d8bbc4f9758136ced17ad495463094e093537319 (commit)
      from  4e095177d8515b17897bcd70f33ad870746303d4 (commit)
revisions in full, below.
commit d8bbc4f9758136ced17ad495463094e093537319
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Nov 22 13:12:42 2023 -0800
    Improve ST_GeneratePoints performance
    for newer GEOS, and in general by
    not testing grid squares that are outside of the shape.
    Fix memory allocation issue for very narrow inputs.
    References #5571
diff --git a/NEWS b/NEWS
index 9d4d58615..6eca201a7 100644
--- a/NEWS
+++ b/NEWS
@@ -20,6 +20,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
   - DocBook5 XSL is now required to build html documentation
     (Sandro Santilli)
   - #5602, Drop support for GEOS 3.6 and 3.7 (Regina Obe)
+  - #5571, Improve ST_GeneratePoints performance, but old
+           seeded pseudo random points will need to be regenerated.
 * New Features *
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 4254b3aae..796f08413 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1277,20 +1277,9 @@ result
         <funcsynopsis>
           <funcprototype>
             <funcdef>geometry <function>ST_GeneratePoints</function></funcdef>
-            <paramdef>
-                <parameter>g</parameter>
-                <type>geometry</type>
-            </paramdef>
-            <paramdef>
-                <parameter>npoints</parameter>
-                <type>integer</type>
-            </paramdef>
-          </funcprototype>
-          <funcprototype>
-            <funcdef>geometry <function>ST_GeneratePoints</function></funcdef>
-            <paramdef> <type>geometry</type> <parameter>g</parameter> </paramdef>
-            <paramdef> <type>integer</type> <parameter>npoints</parameter> </paramdef>
-            <paramdef> <type>integer</type> <parameter>seed = 0</parameter> </paramdef>
+            <paramdef><type>geometry</type> <parameter>g</parameter></paramdef>
+            <paramdef><type>integer</type> <parameter>npoints</parameter></paramdef>
+            <paramdef choice="opt"><type>integer</type> <parameter>seed = 0</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index 44e2187d0..49e5fdf8a 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1658,11 +1658,11 @@ static void test_point_density(void)
 	/* Check if the 1000th point is the expected value.
 	 * Note that if the RNG is not portable, this test may fail. */
 	pt = (LWPOINT*)mpt->geoms[999];
-	// ewkt = lwgeom_to_ewkt((LWGEOM*)pt);
+	// char* ewkt = lwgeom_to_ewkt((LWGEOM*)pt);
 	// printf("%s\n", ewkt);
 	// lwfree(ewkt);
-	CU_ASSERT_DOUBLE_EQUAL(lwpoint_get_x(pt), 0.801167838758, 1e-11);
-	CU_ASSERT_DOUBLE_EQUAL(lwpoint_get_y(pt), 0.345281131175, 1e-11);
+	CU_ASSERT_DOUBLE_EQUAL(lwpoint_get_x(pt), 0.363667838758, 1e-11);
+	CU_ASSERT_DOUBLE_EQUAL(lwpoint_get_y(pt), 0.782781131175, 1e-11);
 	lwmpoint_free(mpt);
 	pt = NULL;
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index d546f42ea..d7aa1cedb 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -1399,10 +1399,31 @@ lwgeom_offsetcurve(const LWGEOM* geom, double size, int quadsegs, int joinStyle,
 	return result;
+static GEOSGeometry*
+lwpoly_to_points_makepoly(double xmin, double ymin, double cell_size)
+	GEOSCoordSequence *cs = GEOSCoordSeq_create(5, 2);
+	GEOSCoordSeq_setXY(cs, 0, xmin, ymin);
+	GEOSCoordSeq_setXY(cs, 1, xmin + cell_size, ymin);
+	GEOSCoordSeq_setXY(cs, 2, xmin + cell_size, ymin + cell_size);
+	GEOSCoordSeq_setXY(cs, 3, xmin, ymin + cell_size);
+	GEOSCoordSeq_setXY(cs, 4, xmin, ymin);
+	return GEOSGeom_createPolygon(GEOSGeom_createLinearRing(cs), NULL, 0);
 LWMPOINT*
 lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
-	double area, bbox_area, bbox_width, bbox_height;
+	typedef struct CellCorner {
+		double x;
+		double y;
+	} CellCorner;
+	CellCorner* cells;
+	uint32_t num_cells = 0;
+	double area, bbox_area, bbox_width, bbox_height, area_ratio;
 	GBOX bbox;
 	const LWGEOM* lwgeom = (LWGEOM*)lwpoly;
 	uint32_t sample_npoints, sample_sqrt, sample_width, sample_height;
@@ -1413,15 +1434,10 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 	uint32_t npoints_tested = 0;
 	GEOSGeometry* g;
 	const GEOSPreparedGeometry* gprep;
-	GEOSGeometry* gpt;
-	GEOSCoordSequence* gseq;
 	LWMPOINT* mpt;
 	int32_t srid = lwgeom_get_srid(lwgeom);
 	int done = 0;
-	int* cells;
-	const size_t size = 2 * sizeof(int);
-	char tmp[2 * sizeof(int)];
-	const size_t stride = 2 * sizeof(int);
 	if (lwgeom_get_type(lwgeom) != POLYGONTYPE)
@@ -1447,15 +1463,20 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 		return NULL;
-	/* Gross up our test set a bit to increase odds of getting coverage in one pass */
-	sample_npoints = npoints * bbox_area / area;
+	/* Gross up our test set a bit to increase odds of getting coverage
+	 * in one pass. For narrow inputs, it is possible we will get
+	 * no hits at all. A fall-back approach might use a random stab-line
+	 * to find pairs of edges that bound interior area, and generate a point
+	 * between those edges, in the case that this gridding system
+	 * does not generate the desired number of points */
+	area_ratio = FP_MIN(bbox_area / area, 10000.0);
+	sample_npoints = npoints * area_ratio;
 	/* We're going to generate points using a sample grid as described
-	 * http://lin-ear-th-inking.blogspot.ca/2010/05/more-random-points-in-jts.html to try and get a more uniform
-	 * "random" set of points. So we have to figure out how to stick a grid into our box */
-	sample_sqrt = lround(sqrt(sample_npoints));
-	if (sample_sqrt == 0)
-		sample_sqrt = 1;
+	 * http://lin-ear-th-inking.blogspot.ca/2010/05/more-random-points-in-jts.html
+	 * to try and get a more uniform "random" set of points. So we have to figure
+	 *  out how to stick a grid into our box */
+	sample_sqrt = ceil(sqrt(sample_npoints));
 	/* Calculate the grids we're going to randomize within */
 	if (bbox_width > bbox_height)
@@ -1481,8 +1502,38 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 	gprep = GEOSPrepare(g);
-	/* Get an empty multi-point ready to return */
-	mpt = lwmpoint_construct_empty(srid, 0, 0);
+	/* Now we fill in an array of cells, only using cells that actually
+	 * intersect the geometry of interest, and finally weshuffle that array,
+	 * so we can visit the cells in random order to avoid visual ugliness
+	 * caused by visiting them sequentially */
+	cells = lwalloc(sizeof(CellCorner) * sample_height * sample_width);
+	for (i = 0; i < sample_width; i++)
+		for (j = 0; j < sample_height; j++)
+			int intersects = 0;
+			double xmin = i * sample_cell_size;
+			double ymin = j * sample_cell_size;
+			GEOSGeometry *gcell = lwpoly_to_points_makepoly(xmin, ymin, sample_cell_size);
+			intersects = GEOSPreparedIntersects(gprep, gcell);
+			if (intersects == 2)
+				GEOSGeom_destroy(gcell);
+				GEOSPreparedGeom_destroy(gprep);
+				GEOSGeom_destroy(g);
+				lwerror("%s: GEOS exception on GEOSPreparedIntersects: %s", __func__, lwgeom_geos_errmsg);
+				return NULL;
+			if (intersects == 1)
+				cells[num_cells].x = xmin;
+				cells[num_cells].y = ymin;
+				num_cells++;
 	/* Initiate random number generator.
 	 * Repeatable numbers are generated with seed values >= 1.
@@ -1490,63 +1541,57 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 	 * Unix time (seconds) and process ID. */
 	lwrandom_set_seed(seed);
-	/* Now we fill in an array of cells, and then shuffle that array, */
-	/* so we can visit the cells in random order to avoid visual ugliness */
-	/* caused by visiting them sequentially */
-	cells = lwalloc(2 * sizeof(int) * sample_height * sample_width);
-	for (i = 0; i < sample_width; i++)
-		for (j = 0; j < sample_height; j++)
-			cells[2 * (i * sample_height + j)] = i;
-			cells[2 * (i * sample_height + j) + 1] = j;
 	/* Fisher-Yates shuffle */
-	n = sample_height * sample_width;
+	n = num_cells;
 	if (n > 1)
 		for (i = n - 1; i > 0; i--)
-			size_t j = (size_t)(lwrandom_uniform() * (i + 1));
-			memcpy(tmp, (char *)cells + j * stride, size);
-			memcpy((char *)cells + j * stride, (char *)cells + i * stride, size);
-			memcpy((char *)cells + i * stride, tmp, size);
+			CellCorner tmp;
+			j = (uint32_t)(lwrandom_uniform() * (i + 1));
+			memcpy(     &tmp, cells + j, sizeof(CellCorner));
+			memcpy(cells + j, cells + i, sizeof(CellCorner));
+			memcpy(cells + i,      &tmp, sizeof(CellCorner));
+	/* Get an empty multi-point ready to return */
+	mpt = lwmpoint_construct_empty(srid, 0, 0);
 	/* Start testing points */
 	while (npoints_generated < npoints)
 		iterations++;
-		for (i = 0; i < sample_width * sample_height; i++)
+		for (i = 0; i < num_cells; i++)
 			int contains = 0;
-			double y = bbox.ymin + cells[2 * i] * sample_cell_size;
-			double x = bbox.xmin + cells[2 * i + 1] * sample_cell_size;
+			double y = cells[i].y;
+			double x = cells[i].x;
 			x += lwrandom_uniform() * sample_cell_size;
 			y += lwrandom_uniform() * sample_cell_size;
 			if (x >= bbox.xmax || y >= bbox.ymax) continue;
-			gseq = GEOSCoordSeq_create(1, 2);
-			GEOSCoordSeq_setXY(gseq, 0, x, y);
-			gpt = GEOSGeom_createPoint(gseq);
-			contains = GEOSPreparedIntersects(gprep, gpt);
-			GEOSGeom_destroy(gpt);
+#if POSTGIS_GEOS_VERSION >= 31200
+			contains = GEOSPreparedIntersectsXY(gprep, x, y);
+#else
+				GEOSGeometry *gpt;
+				GEOSCoordSequence *gseq = GEOSCoordSeq_create(1, 2);;
+				GEOSCoordSeq_setXY(gseq, 0, x, y);
+				gpt = GEOSGeom_createPoint(gseq);
+				contains = GEOSPreparedIntersects(gprep, gpt);
+				GEOSGeom_destroy(gpt);
+#endif
 			if (contains == 2)
-				lwerror("%s: GEOS exception on PreparedContains: %s", __func__, lwgeom_geos_errmsg);
 				return NULL;
-			if (contains)
+			if (contains == 1)
 				npoints_generated++;
 				mpt = lwmpoint_add_lwpoint(mpt, lwpoint_make2d(srid, x, y));
diff --git a/regress/core/regress_brin_index_expected b/regress/core/regress_brin_index_expected
index 5b2c99e3c..2a042a670 100644
--- a/regress/core/regress_brin_index_expected
+++ b/regress/core/regress_brin_index_expected
@@ -1,62 +1,62 @@
 scan_seq|Seq Scan
-5323|POINT(134.204197 130.674106)
 11208|POINT(126.522745 128.356924)
-27373|POINT(129.481991 125.755641)
-33863|POINT(127.143785 131.932614)
+19845|POINT(127.584643 134.083138)
+27373|POINT(125.017705 130.219927)
+33863|POINT(131.608071 127.468328)
 45851|POINT(130.986464 132.890625)
 scan_seq|Seq Scan
 scan_seq|Seq Scan
 scan_idx|Bitmap Heap Scan,Bitmap Index Scan
 scan_seq|Seq Scan
 scan_seq|Seq Scan
 2d|1
diff --git a/regress/core/regress_index_expected b/regress/core/regress_index_expected
index 8872c19ef..cfc954ecf 100644
--- a/regress/core/regress_index_expected
+++ b/regress/core/regress_index_expected
@@ -1,21 +1,21 @@
 scan_idx|Seq Scan
 scan_seq|Index Scan
 &&|1|5+-5:true
-&&|2|907+-60:true
+&&|2|912+-60:true
 &&|3|12505+-500:true
 &&|4|50000+-600:true
 expr &&|1|5+-5:true
-expr &&|2|907+-60:true
+expr &&|2|912+-60:true
 expr &&|3|12505+-500:true
 expr &&|4|50000+-600:true
 _st_sortablehash|0|768602608280535040|768602608280535040
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 4f246275d..8fcc885e3 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1252,10 +1252,10 @@ SELECT '#4299', ST_Disjoint(ST_GeneratePoints(g, 1000), ST_GeneratePoints(g, 100
 FROM (SELECT 'POLYGON((0 0,1 0,1 1,0 1,0 0))'::geometry AS g) AS f;
 -- #4304
-SELECT '#4304', ST_Equals(ST_GeneratePoints(g, 1000, 12345), ST_GeneratePoints(g, 1000, 12345)),
-ST_Disjoint(ST_GeneratePoints(g, 1000, 12345), ST_GeneratePoints(g, 1000, 54321)),
-ST_Disjoint(ST_GeneratePoints(g, 1000, 12345), ST_GeneratePoints(g, 1000)),
-ST_Distance(ST_GeometryN(ST_GeneratePoints(g, 1000, 12345), 1000), 'POINT(0.801167838758 0.345281131175)'::geometry) < 1e-11
+SELECT '#4304',
+  ST_Equals(ST_GeneratePoints(g, 1000, 12345), ST_GeneratePoints(g, 1000, 12345)),
+  ST_Disjoint(ST_GeneratePoints(g, 1000, 12345), ST_GeneratePoints(g, 1000, 54321)),
+  ST_Disjoint(ST_GeneratePoints(g, 1000, 12345), ST_GeneratePoints(g, 1000))
 -- #4331
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 44e4f6e65..145994491 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -384,7 +384,7 @@ equals211|t
 equals212|t
 equals213|t
 #4299|t
-#4304|t|t|t|t
+#4304|t|t|t
 ERROR:  BOX3D_construct: args can not be empty points
 ERROR:  BOX2D_construct: args can not be empty points
 #4176|t
Summary of changes:
 NEWS                                     |   2 +
 doc/reference_processing.xml             |  17 +---
 liblwgeom/cunit/cu_algorithm.c           |   6 +-
 liblwgeom/lwgeom_geos.c                  | 139 ++++++++++++++++++++-----------
 regress/core/regress_brin_index_expected |  60 ++++++-------
 regress/core/regress_index_expected      |  16 ++--
 regress/core/tickets.sql                 |   8 +-
 regress/core/tickets_expected            |   2 +-
 8 files changed, 143 insertions(+), 107 deletions(-)
hooks/post-receive
