[SCM] PostGIS branch master updated. 3.4.0rc1-794-g6db05647f
Thu Nov 23 09:50:11 PST 2023
the project "PostGIS".
       via  6db05647f6e11cfe4c1b4f2f457eb20fdc23e194 (commit)
      from  b9a7018bd33f1076a4cdaf2c4d1421e175ec3563 (commit)
revisions in full, below.
commit 6db05647f6e11cfe4c1b4f2f457eb20fdc23e194
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Nov 23 09:50:06 2023 -0800
    Reorganize PiP cache tree a little
diff --git a/postgis/lwgeom_functions_analytic.c b/postgis/lwgeom_functions_analytic.c
index 24fc11794..aae248c1c 100644
--- a/postgis/lwgeom_functions_analytic.c
+++ b/postgis/lwgeom_functions_analytic.c
@@ -47,10 +47,84 @@ Datum ST_IsPolygonCCW(PG_FUNCTION_ARGS);
 Datum ST_IsPolygonCW(PG_FUNCTION_ARGS);
-static double determineSide(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point);
-static int isOnSegment(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point);
-static int point_in_ring(POINTARRAY *pts, const POINT2D *point);
-static int point_in_ring_rtree(RTREE_NODE *root, const POINT2D *point);
+ * return -1 iff point is outside ring pts
+ * return 1 iff point is inside ring pts
+ * return 0 iff point is on ring pts
+static int point_in_ring(POINTARRAY *pts, const POINT2D *point)
+	int wn = 0;
+	uint32_t i;
+	double side;
+	const POINT2D* seg1;
+	const POINT2D* seg2;
+	POSTGIS_DEBUG(2, "point_in_ring called.");
+	seg2 = getPoint2d_cp(pts, 0);
+	for (i=0; i<pts->npoints-1; i++)
+		seg1 = seg2;
+		seg2 = getPoint2d_cp(pts, i+1);
+		side = determineSide(seg1, seg2, point);
+		POSTGIS_DEBUGF(3, "segment: (%.8f, %.8f),(%.8f, %.8f)", seg1->x, seg1->y, seg2->x, seg2->y);
+		POSTGIS_DEBUGF(3, "side result: %.8f", side);
+		POSTGIS_DEBUGF(3, "counterclockwise wrap %d, clockwise wrap %d", FP_CONTAINS_BOTTOM(seg1->y, point->y, seg2->y), FP_CONTAINS_BOTTOM(seg2->y, point->y, seg1->y));
+		/* zero length segments are ignored. */
+		if ((seg2->x == seg1->x) && (seg2->y == seg1->y))
+			POSTGIS_DEBUG(3, "segment is zero length... ignoring.");
+			continue;
+		/* a point on the boundary of a ring is not contained. */
+		/* WAS: if (fabs(side) < 1e-12), see #852 */
+		if (side == 0.0)
+			if (isOnSegment(seg1, seg2, point) == 1)
+				POSTGIS_DEBUGF(3, "point on ring boundary between points %d, %d", i, i+1);
+				return 0;
+		 * If the point is to the left of the line, and it's rising,
+		 * then the line is to the right of the point and
+		 * circling counter-clockwise, so increment.
+		if ((seg1->y <= point->y) && (point->y < seg2->y) && (side > 0))
+			POSTGIS_DEBUG(3, "incrementing winding number.");
+			++wn;
+		 * If the point is to the right of the line, and it's falling,
+		 * then the line is to the right of the point and circling
+		 * clockwise, so decrement.
+		else if ((seg2->y <= point->y) && (point->y < seg1->y) && (side < 0))
+			POSTGIS_DEBUG(3, "decrementing winding number.");
+			--wn;
+	POSTGIS_DEBUGF(3, "winding number %d", wn);
+	if (wn == 0)
+		return -1;
+	return 1;
  * Simple Douglas-Peucker line simplification.
@@ -668,7 +742,7 @@ Datum LWGEOM_line_substring(PG_FUNCTION_ARGS)
  *          <0 for a point to the right of the segment,
  *          0 for a point on the segment
+double determineSide(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point)
 	return ((seg2->x-seg1->x)*(point->y-seg1->y)-(point->x-seg1->x)*(seg2->y-seg1->y));
@@ -682,7 +756,7 @@ static double determineSide(const POINT2D *seg1, const POINT2D *seg2, const POIN
  * returns: 1 if the point is not outside the bounds of the segment
  *          0 if it is
+int isOnSegment(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point)
 	double maxX;
 	double maxY;
@@ -727,266 +801,7 @@ static int isOnSegment(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *
 	return 1;
- * return -1 iff point is outside ring pts
- * return 1 iff point is inside ring pts
- * return 0 iff point is on ring pts
-	int wn = 0;
-	uint32_t i;
-	double side;
-	const POINT2D *seg1;
-	const POINT2D *seg2;
-	LWMLINE *lines;
-	POSTGIS_DEBUG(2, "point_in_ring called.");
-	lines = RTreeFindLineSegments(root, point->y);
-	if (!lines)
-		return -1;
-	for (i=0; i<lines->ngeoms; i++)
-		seg1 = getPoint2d_cp(lines->geoms[i]->points, 0);
-		seg2 = getPoint2d_cp(lines->geoms[i]->points, 1);
-		side = determineSide(seg1, seg2, point);
-		POSTGIS_DEBUGF(3, "segment: (%.8f, %.8f),(%.8f, %.8f)", seg1->x, seg1->y, seg2->x, seg2->y);
-		POSTGIS_DEBUGF(3, "side result: %.8f", side);
-		POSTGIS_DEBUGF(3, "counterclockwise wrap %d, clockwise wrap %d", FP_CONTAINS_BOTTOM(seg1->y, point->y, seg2->y), FP_CONTAINS_BOTTOM(seg2->y, point->y, seg1->y));
-		/* zero length segments are ignored. */
-		if (((seg2->x - seg1->x)*(seg2->x - seg1->x) + (seg2->y - seg1->y)*(seg2->y - seg1->y)) < 1e-12*1e-12)
-			POSTGIS_DEBUG(3, "segment is zero length... ignoring.");
-			continue;
-		/* a point on the boundary of a ring is not contained. */
-		/* WAS: if (fabs(side) < 1e-12), see #852 */
-		if (side == 0.0)
-			if (isOnSegment(seg1, seg2, point) == 1)
-				POSTGIS_DEBUGF(3, "point on ring boundary between points %d, %d", i, i+1);
-				return 0;
-		 * If the point is to the left of the line, and it's rising,
-		 * then the line is to the right of the point and
-		 * circling counter-clockwise, so increment.
-		if ((seg1->y <= point->y) && (point->y < seg2->y) && (side > 0))
-			POSTGIS_DEBUG(3, "incrementing winding number.");
-			++wn;
-		 * If the point is to the right of the line, and it's falling,
-		 * then the line is to the right of the point and circling
-		 * clockwise, so decrement.
-		else if ((seg2->y <= point->y) && (point->y < seg1->y) && (side < 0))
-			POSTGIS_DEBUG(3, "decrementing winding number.");
-			--wn;
-	POSTGIS_DEBUGF(3, "winding number %d", wn);
-	if (wn == 0)
-		return -1;
-	return 1;
-	int wn = 0;
-	uint32_t i;
-	double side;
-	const POINT2D* seg1;
-	const POINT2D* seg2;
-	seg2 = getPoint2d_cp(pts, 0);
-	for (i=0; i<pts->npoints-1; i++)
-		seg1 = seg2;
-		seg2 = getPoint2d_cp(pts, i+1);
-		if ((seg2->x == seg1->x) && (seg2->y == seg1->y))
-			continue;
-		if (side == 0.0)
-				return 0;
-			++wn;
-			--wn;
-	if (wn == 0)
-		return -1;
-	return 1;
- * return 0 iff point outside polygon or on boundary
- * return 1 iff point inside polygon
-int point_in_polygon_rtree(RTREE_NODE **root, int ringCount, LWPOINT *point)
-	int i;
-	POINT2D pt;
-	POSTGIS_DEBUGF(2, "point_in_polygon called for %p %d %p.", root, ringCount, point);
-	getPoint2d_p(point->point, 0, &pt);
-	/* assume bbox short-circuit has already been attempted */
-	if (point_in_ring_rtree(root[0], &pt) != 1)
-		POSTGIS_DEBUG(3, "point_in_polygon_rtree: outside exterior ring.");
-		return 0;
-	for (i=1; i<ringCount; i++)
-		if (point_in_ring_rtree(root[i], &pt) != -1)
-			POSTGIS_DEBUGF(3, "point_in_polygon_rtree: within hole %d.", i);
-			return 0;
-	return 1;
- * return -1 if point outside polygon
- * return 0 if point on boundary
- * return 1 if point inside polygon
- * Expected **root order is each exterior ring followed by its holes, eg. EIIEIIEI
-int point_in_multipolygon_rtree(RTREE_NODE **root, int polyCount, int *ringCounts, LWPOINT *point)
-	int i, p, r, in_ring;
-	POINT2D pt;
-	int result = -1;
-	POSTGIS_DEBUGF(2, "point_in_multipolygon_rtree called for %p %d %p.", root, polyCount, point);
-        i = 0; /* the current index into the root array */
-	/* is the point inside any of the sub-polygons? */
-	for ( p = 0; p < polyCount; p++ )
-		in_ring = point_in_ring_rtree(root[i], &pt);
-		POSTGIS_DEBUGF(4, "point_in_multipolygon_rtree: exterior ring (%d), point_in_ring returned %d", p, in_ring);
-		if ( in_ring == -1 ) /* outside the exterior ring */
-			POSTGIS_DEBUG(3, "point_in_multipolygon_rtree: outside exterior ring.");
-         	else if ( in_ring == 0 ) /* on the boundary */
-			POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: on edge of exterior ring %d", p);
-                        return 0;
-		} else {
-                	result = in_ring;
-	                for(r=1; r<ringCounts[p]; r++)
-                        	in_ring = point_in_ring_rtree(root[i+r], &pt);
-		        	POSTGIS_DEBUGF(4, "point_in_multipolygon_rtree: interior ring (%d), point_in_ring returned %d", r, in_ring);
-                        	if (in_ring == 1) /* inside a hole => outside the polygon */
-                                	POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: within hole %d of exterior ring %d", r, p);
-                                	result = -1;
-                                	break;
-                        	if (in_ring == 0) /* on the edge of a hole */
-			        	POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: on edge of hole %d of exterior ring %d", r, p);
-                                	return 0;
-                	/* if we have a positive result, we can short-circuit and return it */
-                	if ( result != -1)
-                        	return result;
-                /* increment the index by the total number of rings in the sub-poly */
-                /* we do this here in case we short-cutted out of the poly before looking at all the rings */
-                i += ringCounts[p];
-	return result; /* -1 = outside, 0 = boundary, 1 = inside */
  * return -1 iff point outside polygon
@@ -1125,7 +940,7 @@ Datum ST_MinimumBoundingRadius(PG_FUNCTION_ARGS)
 	geom = PG_GETARG_GSERIALIZED_P(0);
-    /* Empty geometry?  Return POINT EMPTY with zero radius */
+	/* Empty geometry?  Return POINT EMPTY with zero radius */
 	if (gserialized_is_empty(geom))
 		lwcenter = (LWGEOM*) lwpoint_construct_empty(gserialized_get_srid(geom), LW_FALSE, LW_FALSE);
diff --git a/postgis/lwgeom_functions_analytic.h b/postgis/lwgeom_functions_analytic.h
index 10cb73b04..79d05ec79 100644
--- a/postgis/lwgeom_functions_analytic.h
+++ b/postgis/lwgeom_functions_analytic.h
@@ -29,8 +29,8 @@
 ** Public prototypes for analytic functions.
-int point_in_polygon_rtree(RTREE_NODE **root, int ringCount, LWPOINT *point);
-int point_in_multipolygon_rtree(RTREE_NODE **root, int polyCount, int *ringCounts, LWPOINT *point);
 int point_in_polygon(LWPOLY *polygon, LWPOINT *point);
 int point_in_multipolygon(LWMPOLY *mpolygon, LWPOINT *pont);
+double determineSide(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point);
+int isOnSegment(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point);
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 43d5cfd63..dc6aab8e9 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -133,34 +133,6 @@ is_point(const GSERIALIZED* g)
 	return type == POINTTYPE || type == MULTIPOINTTYPE;
-/* Utility function that checks a LWPOINT and a GSERIALIZED poly against a cache.
- * Serialized poly may be a multipart.
-static int
-pip_short_circuit(RTREE_POLY_CACHE *poly_cache, LWPOINT *point, const GSERIALIZED *gpoly)
-	int result;
-	if ( poly_cache && poly_cache->ringIndices )
-        result = point_in_multipolygon_rtree(poly_cache->ringIndices, poly_cache->polyCount, poly_cache->ringCounts, point);
-	else
-		LWGEOM* poly = lwgeom_from_gserialized(gpoly);
-		if ( lwgeom_get_type(poly) == POLYGONTYPE )
-			result = point_in_polygon(lwgeom_as_lwpoly(poly), point);
-		else
-			result = point_in_multipolygon(lwgeom_as_lwmpoly(poly), point);
-		lwgeom_free(poly);
-	return result;
  *  @brief Compute the Hausdorff distance thanks to the corresponding GEOS function
@@ -2858,19 +2830,23 @@ POSTGIS2GEOS(const GSERIALIZED *pglwgeom)
 	return ret;
-uint32_t array_nelems_not_null(ArrayType* array) {
-    ArrayIterator iterator;
-    Datum value;
-    bool isnull;
-    uint32_t nelems_not_null = 0;
+static uint32_t
+array_nelems_not_null(ArrayType* array)
+	ArrayIterator iterator;
+	Datum value;
+	bool isnull;
+	uint32_t nelems_not_null = 0;
 	iterator = array_create_iterator(array, 0, NULL);
-	while(array_iterate(iterator, &value, &isnull) )
-        if (!isnull)
-            nelems_not_null++;
+	while(array_iterate(iterator, &value, &isnull))
+		if (!isnull)
+			nelems_not_null++;
-    array_free_iterator(iterator);
+	array_free_iterator(iterator);
-    return nelems_not_null;
+	return nelems_not_null;
 /* ARRAY2LWGEOM: Converts the non-null elements of a Postgres array into a LWGEOM* array */
diff --git a/postgis/lwgeom_geos.h b/postgis/lwgeom_geos.h
index 3f8d24519..07707c459 100644
--- a/postgis/lwgeom_geos.h
+++ b/postgis/lwgeom_geos.h
@@ -47,8 +47,6 @@ Datum LWGEOM_area_polygon(PG_FUNCTION_ARGS);
 Datum LWGEOM_mindistance2d(PG_FUNCTION_ARGS);
 Datum ST_3DDistance(PG_FUNCTION_ARGS);
-uint32_t array_nelems_not_null(ArrayType* array);
 /* Return NULL on GEOS error
diff --git a/postgis/lwgeom_rtree.c b/postgis/lwgeom_rtree.c
index f743b92ee..2aabb1dbb 100644
--- a/postgis/lwgeom_rtree.c
+++ b/postgis/lwgeom_rtree.c
@@ -28,9 +28,10 @@
 #include "../postgis_config.h"
 #include "lwgeom_pg.h"
 #include "liblwgeom.h"
-#include "liblwgeom_internal.h"         /* For FP comparators. */
+#include "liblwgeom_internal.h" /* For FP comparators. */
 #include "lwgeom_cache.h"
 #include "lwgeom_rtree.h"
+#include "lwgeom_functions_analytic.h"
 /* Prototypes */
@@ -61,7 +62,6 @@ RTreeFree(RTREE_NODE* root)
 		RTreeFree(root->leftNode);
 	if (root->rightNode)
 		RTreeFree(root->rightNode);
-	lwfree(root->interval);
 	if (root->segment)
 		lwline_free(root->segment);
@@ -98,7 +98,7 @@ RTreeCacheClear(RTREE_POLY_CACHE* cache)
  * Returns 1 if min < value <= max, 0 otherwise.
 static uint32
-IntervalIsContained(RTREE_INTERVAL* interval, double value)
+IntervalIsContained(const RTREE_INTERVAL* interval, double value)
 	return FP_CONTAINS_INCL(interval->min, value, interval->max) ? 1 : 0;
@@ -106,40 +106,17 @@ IntervalIsContained(RTREE_INTERVAL* interval, double value)
 * Creates an interval with the total extents of the two given intervals.
-static RTREE_INTERVAL*
-RTreeMergeIntervals(RTREE_INTERVAL *inter1, RTREE_INTERVAL *inter2)
+static void
+RTreeMergeIntervals(
+	const RTREE_INTERVAL *inter1,
+	const RTREE_INTERVAL *inter2,
+	RTREE_INTERVAL *result)
-	RTREE_INTERVAL *interval;
-	POSTGIS_DEBUGF(2, "RTreeMergeIntervals called with %p, %p", inter1, inter2);
-	interval = lwalloc(sizeof(RTREE_INTERVAL));
-	interval->max = FP_MAX(inter1->max, inter2->max);
-	interval->min = FP_MIN(inter1->min, inter2->min);
-	POSTGIS_DEBUGF(3, "interval min = %8.3f, max = %8.3f", interval->min, interval->max);
-	return interval;
+	result->max = FP_MAX(inter1->max, inter2->max);
+	result->min = FP_MIN(inter1->min, inter2->min);
+	return;
-* Creates an interval given the min and max values, in arbitrary order.
-RTreeCreateInterval(double value1, double value2)
-	POSTGIS_DEBUGF(2, "RTreeCreateInterval called with %8.3f, %8.3f", value1, value2);
-	interval->max = FP_MAX(value1, value2);
-	interval->min = FP_MIN(value1, value2);
-	return interval;
 * Creates an interior node given the children.
@@ -154,9 +131,12 @@ RTreeCreateInteriorNode(RTREE_NODE* left, RTREE_NODE* right)
 	parent = lwalloc(sizeof(RTREE_NODE));
 	parent->leftNode = left;
 	parent->rightNode = right;
-	parent->interval = RTreeMergeIntervals(left->interval, right->interval);
 	parent->segment = NULL;
+	RTreeMergeIntervals(
+		&(left->interval), &(right->interval),
+		&(parent->interval));
 	POSTGIS_DEBUGF(3, "RTreeCreateInteriorNode returning %p", parent);
 	return parent;
@@ -200,7 +180,8 @@ RTreeCreateLeafNode(POINTARRAY* pa, uint32_t startPoint)
 	line = lwline_construct(SRID_UNKNOWN, NULL, npa);
-	parent->interval = RTreeCreateInterval(value1, value2);
+	parent->interval.min = FP_MIN(value1, value2);
+	parent->interval.max = FP_MAX(value1, value2);
 	parent->segment = line;
 	parent->leftNode = NULL;
 	parent->rightNode = NULL;
@@ -350,9 +331,9 @@ RTreeBuilder(const LWGEOM* lwgeom, GeomCache* cache)
 		currentCache->ringIndices = lwalloc(sizeof(RTREE_NODE *) * nrings);
 		** Load the array in geometry order, each outer ring followed by the inner rings
-                ** associated with that outer ring
+		** associated with that outer ring
-                i = 0;
+		i = 0;
 		for ( p = 0; p < mpoly->ngeoms; p++ )
 			for ( r = 0; r < mpoly->geoms[p]->nrings; r++ )
@@ -456,7 +437,7 @@ LWMLINE *RTreeFindLineSegments(RTREE_NODE *root, double value)
 	result = NULL;
-	if (!IntervalIsContained(root->interval, value))
+	if (!IntervalIsContained(&(root->interval), value))
 		POSTGIS_DEBUGF(3, "RTreeFindLineSegments %p: not contained.", root);
@@ -515,3 +496,180 @@ LWMLINE *RTreeFindLineSegments(RTREE_NODE *root, double value)
+static int point_in_ring_rtree(RTREE_NODE *root, const POINT2D *point)
+	int wn = 0;
+	uint32_t i;
+	double side;
+	const POINT2D *seg1;
+	const POINT2D *seg2;
+	LWMLINE *lines;
+	lines = RTreeFindLineSegments(root, point->y);
+	if (!lines)
+		return -1;
+	for (i=0; i<lines->ngeoms; i++)
+		seg1 = getPoint2d_cp(lines->geoms[i]->points, 0);
+		seg2 = getPoint2d_cp(lines->geoms[i]->points, 1);
+		if (((seg2->x - seg1->x)*(seg2->x - seg1->x) + (seg2->y - seg1->y)*(seg2->y - seg1->y)) < 1e-12*1e-12)
+			continue;
+		if (side == 0.0)
+				return 0;
+			++wn;
+			--wn;
+	if (wn == 0)
+		return -1;
+	return 1;
+ * return -1 if point outside polygon
+ * return 0 if point on boundary
+ * return 1 if point inside polygon
+ * Expected **root order is each exterior ring followed by its holes, eg. EIIEIIEI
+static int
+point_in_multipolygon_rtree(RTREE_NODE **root, int polyCount, int *ringCounts, LWPOINT *point)
+	int i, p, r, in_ring;
+	const POINT2D *pt;
+	int result = -1;
+	POSTGIS_DEBUGF(2, "point_in_multipolygon_rtree called for %p %d %p.", root, polyCount, point);
+	pt = getPoint2d_cp(point->point, 0);
+	/* assume bbox short-circuit has already been attempted */
+	i = 0; /* the current index into the root array */
+	/* is the point inside any of the sub-polygons? */
+	for ( p = 0; p < polyCount; p++ )
+		in_ring = point_in_ring_rtree(root[i], pt);
+		POSTGIS_DEBUGF(4, "point_in_multipolygon_rtree: exterior ring (%d), point_in_ring returned %d", p, in_ring);
+		if ( in_ring == -1 ) /* outside the exterior ring */
+			POSTGIS_DEBUG(3, "point_in_multipolygon_rtree: outside exterior ring.");
+		else if ( in_ring == 0 ) /* on the boundary */
+			POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: on edge of exterior ring %d", p);
+			return 0;
+		else
+			result = in_ring;
+			for(r = 1; r < ringCounts[p]; r++)
+				in_ring = point_in_ring_rtree(root[i+r], pt);
+				POSTGIS_DEBUGF(4, "point_in_multipolygon_rtree: interior ring (%d), point_in_ring returned %d", r, in_ring);
+				if (in_ring == 1) /* inside a hole => outside the polygon */
+					POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: within hole %d of exterior ring %d", r, p);
+					result = -1;
+					break;
+				if (in_ring == 0) /* on the edge of a hole */
+					POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: on edge of hole %d of exterior ring %d", r, p);
+					return 0;
+			/* if we have a positive result, we can short-circuit and return it */
+			if (result != -1)
+				return result;
+		/* increment the index by the total number of rings in the sub-poly */
+		/* we do this here in case we short-cutted out of the poly before looking at all the rings */
+		i += ringCounts[p];
+	return result; /* -1 = outside, 0 = boundary, 1 = inside */
+/* Utility function that checks a LWPOINT and a GSERIALIZED poly against a cache.
+ * Serialized poly may be a multipart.
+int
+pip_short_circuit(RTREE_POLY_CACHE *poly_cache, LWPOINT *point, const GSERIALIZED *gpoly)
+	int result;
+	if (poly_cache && poly_cache->ringIndices)
+		result = point_in_multipolygon_rtree(poly_cache->ringIndices, poly_cache->polyCount, poly_cache->ringCounts, point);
+	else
+		LWGEOM* poly = lwgeom_from_gserialized(gpoly);
+		if (lwgeom_get_type(poly) == POLYGONTYPE)
+			result = point_in_polygon(lwgeom_as_lwpoly(poly), point);
+		else
+			result = point_in_multipolygon(lwgeom_as_lwmpoly(poly), point);
+		lwgeom_free(poly);
+	return result;
diff --git a/postgis/lwgeom_rtree.h b/postgis/lwgeom_rtree.h
index 84efc0769..41db74aae 100644
--- a/postgis/lwgeom_rtree.h
+++ b/postgis/lwgeom_rtree.h
@@ -45,7 +45,7 @@ RTREE_INTERVAL;
 typedef struct rtree_node
+	RTREE_INTERVAL interval;
 	struct rtree_node *leftNode;
 	struct rtree_node *rightNode;
 	LWLINE *segment;
@@ -82,4 +82,6 @@ LWMLINE *RTreeFindLineSegments(RTREE_NODE *root, double value);
 RTREE_POLY_CACHE *GetRtreeCache(FunctionCallInfo fcinfo, SHARED_GSERIALIZED *g1);
+int pip_short_circuit(RTREE_POLY_CACHE *poly_cache, LWPOINT *point, const GSERIALIZED *gpoly);
 #endif /* !defined _LWGEOM_RTREE_H */
Summary of changes:
 postgis/lwgeom_functions_analytic.c | 347 +++++++++---------------------------
 postgis/lwgeom_functions_analytic.h |   4 +-
 postgis/lwgeom_geos.c               |  52 ++----
 postgis/lwgeom_geos.h               |   2 -
 postgis/lwgeom_rtree.c              | 236 ++++++++++++++++++++----
 postgis/lwgeom_rtree.h              |   4 +-
 6 files changed, 297 insertions(+), 348 deletions(-)
hooks/post-receive
