[PostGIS] #5619: ST_Intersection, side location conflict on Postgis 3.4
PostGIS trac at osgeo.org
Sat Nov 25 18:59:24 PST 2023
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.2
 Component:  postgis            |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by robe):
 Replying to [comment:2 Lars Aksel Opsahl]:
 > The server with Postgis 3.4.0 was built from scratch with (Ubuntu
 22.04.3 LTS) about 2 weeks ago, with latest off everything , but I will
 ask them if it's possible to get upgrade on geos of course on that server
 How did you manage to get your 3.3 with a newer GEOS or did you compile
 that GEOS yourself?
 > By the way when checking PostGIS_Full_Version() could it there be
 message about geos that maybe it should be upgraded to a newer version or
 something like that ?
 > Thanks
 I don't think we can do that with GEOS, because people are allowed to run
 any GEOS that is supported for that version of PostGIS.
 Also GEOS tends to be a system library shipped with the OS, so it's hard
 for a user to upgrade it short of not using the distro and compiling their
 own GEOS.
 Also it's hard to know what the latest (even micro version) is of GEOS
 since PostGIS and GEOS have slightly different release cycles. GEOS we try
 to release a new minor version about a month before the PostGIS that
 exposes features of that version comes out, but the micro releases of each
 are detached and happen whenever a sufficient number of bugs or serious
 bugs piles up for the respective software.
 The best we can maybe put in that note, is "You are using a GEOS version
 that does not support all the functions of this release.  As such several
 functions will be disabled"
 But none of that is going to help with this ticket since your issue is you
 are running an out of date geos for your micros
 Latest micros are listed here - https://libgeos.org/usage/download/
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5619#comment:3>
