[PostGIS] #5619: ST_Intersection, side location conflict on Postgis 3.4
PostGIS trac at osgeo.org
Mon Nov 27 16:55:21 PST 2023
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.2
 Component:  postgis            |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by robe):
 > I think just a text message indicating that geos is out off date would
 be a very nice help, since this is a problem on newly installed Ubuntu
 (libgeos-c1v5/jammy,now 3.10.2-1 amd64 [installed,automatic]) servers
 where only apt is used to install postgis with out doing any compiling of
 any code.
 > Thanks
 I'm trying to think how we can do that, and I still feel the effort vs.
 the utility gained is not there.
 I'd be more worried causing undue panic than providing any useful
 information.
 First of all what would you consider an out-of-date geos?
 Often times a new micro release of GEOS will come out after a new PostGIS
 micro, so we can't really know that GEOS is out of date.
 The GEOS micro that was the latest when PostGIS was released has a bug in
 it that you are experiencing, that PostGIS couldn't possibly know about
 because it came after the PostGIS release.  Your geos is out of date, but
 we can't tell you that.
 That is often the case I see, which is why we mark those kind of bugs as
 GEOS (cause they aren't fixed in PostGIS, but GEOS), upgrade your GEOS and
 you don't even need to recompile PostGIS to fix.
 Also if you are using a PostGIS that exercises new features, but your GEOS
 is the latest micro, but not latest minor. e.g. you are running GEOS
 3.10.6 with PostGIS 3.4.1.  Does that mean your GEOS is out of date?  Well
 from the micro stand point it isn't (and sadly that's the best we can hope
 for from packagers, cause they still try to stare away from upgrade GEOS
 to latest minor, like it's some sacred thing that will break everything
 else), from the major, well you are missing out on some functions.
 Say for example you are running PostGIS 3.4.1, you would be missing out on
 GEOS 3.11 features like the HULL functions e.g.
 https://postgis.net/docs/ST_SimplifyPolygonHull.html  - but maybe you
 don't care.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5619#comment:6>
