[PostGIS] #5624: Provide more info about out of date geos when checking PostGIS_Full_Version() ;
PostGIS trac at osgeo.org
Mon Nov 27 23:08:44 PST 2023
 Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.4.2
Component:  postgis            |    Version:  3.4.x
 Keywords:                     |
 == Case 1 (using a EOL geos)
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.10.1-CAPI-1.16.0"
 SFCGAL="1.3.7" PROJ="8.2.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.10" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
 Then a message like this could be added
 Your geos has reached EOL, please try to upgrade your geos. To be sure to
 get all feature supported latest geos at
 [https://libgeos.org/usage/download/]
 == Case 2 (Using a valid geos, but not latest)
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.10.6"
 Your geos is valid, but to be sure to get all feature supported try to use
 latest geos at [https://libgeos.org/usage/download/]
 == Case 3 (Using a latest geos or newer)
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.12.1"
 There is no printed message about geos
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5624>
