[PostGIS] #5623: unpackaged upgrade from PostGIS 3.2 failing on ST_AsGeoJSON
PostGIS trac at osgeo.org
Tue Nov 28 00:01:29 PST 2023
  Reporter:  robe          |      Owner:  strk
      Type:  defect        |     Status:  new
  Priority:  blocker       |  Milestone:  PostGIS 3.5.0
 Component:  upgrade/hard  |    Version:  master
Resolution:                |   Keywords:
Comment (by strk):
 I think it should be ok to use _postgis_drop_function_by_identity in
 postgis_drop_before  as you did, although I wonder why you didn't use a
 Replaces tag instead, which would have been quicker to type.
 I'll see to reproduce locally to fix it
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5623#comment:1>
