[PostGIS] #5626: ST_LargestEmptyCircle crashes on GEOS 3.13 with Triangle
PostGIS trac at osgeo.org
Tue Nov 28 19:45:53 PST 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> SELECT ST_LargestEmptyCircle('POINT(-11.1111111 40)'::geometry, 20.1,
> 'TRIANGLE((-71.0821 42.3036,-71.0821 42.3936,-71.0901 42.3036,-71.0821
> 42.3036))'::geometry )
> berrie64 which also does crasher tests seems to have gone thru fine
> (though I just checked and she's only testing GEOS 3.12.0 so have to up
> that), so maybe this only affects GEOS 3.13.
> I'm running with a week old geos, and will test after my latest is
> rebuilt.
> I'm surprised GEOS even works with triangles.  When did this happen.
> Should it be erroring out, or does GEOS now support triangles?
> This is running with
> POSTGIS="3.5.0dev 3.4.0rc1-806-g59aba6dcb" [EXTENSION] PGSQL="160"
> GEOS="3.13.0dev-CAPI-1.18.0" SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST
> 1.78.0" PROJ="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj
> DATABASE_PATH=C:\ming64gcc81\projects\proj\rel-
> proj-8.2.1w64gcc81/share/proj/proj.db" LIBXML="2.9.14" LIBJSON="0.12"
> LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
New description:
 rebuilt.
 GEOS="3.13.0dev-CAPI-1.18.0" SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.78.0"
 LIBXML="2.9.14" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
 (Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5626#comment:2>
