[SCM] PostGIS branch master updated. 3.4.0rc1-816-g6d04153da
Tue Nov 28 20:00:48 PST 2023
the project "PostGIS".
       via  6d04153dade65539860d5053862aae191e162c2f (commit)
       via  b9de4ae6113de6e86b85191abc6fcd7d2155a1a0 (commit)
       via  9a7f57268d92570955255a33b8e6f497fdfce97d (commit)
      from  f797790126102762e311e738022197c7bf417609 (commit)
revisions in full, below.
commit 6d04153dade65539860d5053862aae191e162c2f
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 28 23:00:42 2023 -0500
    Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index c50ccc76e..44f737243 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-11-26 01:47+0000\n"
+"POT-Creation-Date: 2023-11-29 04:00+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -8042,6 +8042,11 @@ msgstr ""
 msgid "Jan Katins"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Jan Tojnar"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Jason Smith"
@@ -13224,27 +13229,6 @@ msgstr ""
 msgid "Changed: 3.1.0. Added support for supplying non-zero Z and M values."
 msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Orients all exterior rings counter-clockwise and all interior rings "
-"clockwise."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Forces (Multi)Polygons to use a counter-clockwise orientation for their "
-"exterior ring, and a clockwise orientation for their interior rings. Non-"
-"polygonal geometries are returned unchanged."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-", <xref linkend=\"ST_IsPolygonCCW\"/>, <xref linkend=\"ST_IsPolygonCW\"/>"
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Convert the geometry into a GEOMETRYCOLLECTION."
@@ -13269,6 +13253,41 @@ msgstr ""
 msgid "Changed: 2.1.0. Up to 2.0.x this was called ST_Force_Collection."
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Upcast a geometry into its curved type, if applicable."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Turns a geometry into its curved representation, if applicable: lines become "
+"compoundcurves, multilines become multicurves polygons become curvepolygons "
+"multipolygons become multisurfaces. If the geometry input is already a "
+"curved representation returns back same as input."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Orients all exterior rings counter-clockwise and all interior rings "
+"clockwise."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Forces (Multi)Polygons to use a counter-clockwise orientation for their "
+"exterior ring, and a clockwise orientation for their interior rings. Non-"
+"polygonal geometries are returned unchanged."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_IsPolygonCCW\"/>, <xref linkend=\"ST_IsPolygonCW\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -13324,16 +13343,27 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
-msgid "Upcast a geometry into its curved type, if applicable."
+msgid "Returns a line extended forwards and backwards by specified distances."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Turns a geometry into its curved representation, if applicable: lines become "
-"compoundcurves, multilines become multicurves polygons become curvepolygons "
-"multipolygons become multisurfaces. If the geometry input is already a "
-"curved representation returns back same as input."
+"Returns a line extended forwards and backwards by adding new start (and end) "
+"points at the given distance(s). A distance of zero does not add a point. "
+"Only non-negative distances are allowed. The direction(s) of the added "
+"point(s) is determined by the first (and last) two distinct points of the "
+"line. Duplicate points are ignored."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Example: Extends a line 5 units forward and 6 units backward"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_LocateAlong\"/>, <xref linkend=\"ST_Project\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -13367,33 +13397,6 @@ msgid ""
 "already a collection, it is returned unchanged."
 msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Returns a line with the last and first segments extended the specified "
-"distance(s)."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"distance(s). Distance of zero carries out no extension. Only non-negative "
-"distances are allowed. The first (and last) two distinct points in a line "
-"are used to determine the direction of projection, duplicate points are "
-"ignored."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Example: Extends a line 5 units forward and 6 units backward"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_Project\"/>"
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Return the geometry in its canonical form."
@@ -15799,8 +15802,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"ST_LineInterpolatePoint\"/>, <xref "
-"linkend=\"ST_LineMerge\"/>"
+", <xref linkend=\"ST_LineExtend\"/>, <xref "
+"linkend=\"ST_LineInterpolatePoint\"/>, <xref linkend=\"ST_LineMerge\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -18902,6 +18905,17 @@ msgstr ""
 msgid "8: GeoJSON Short CRS if not EPSG:4326 (default)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <varname>id_column</varname> parameter is used to set the \"id\" member "
+"of the returned GeoJSON features. As per GeoJSON RFC, this SHOULD be used "
+"whenever a feature has a commonly used identifier, such as a primary key. "
+"When not specified, the produced features will not get an \"id\" member and "
+"any columns other than the geometry, including any potential keys, will just "
+"end up inside the feature’s \"properties\" member."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -18956,6 +18970,11 @@ msgstr ""
 msgid "Changed: 3.0.0 output SRID if not EPSG:4326."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Changed: 3.5.0 allow specifying the column containing the feature id"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Generate a FeatureCollection:"
@@ -18966,13 +18985,6 @@ msgstr ""
 msgid "Generate a Feature:"
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"An alternate way to generate Features with an <varname>id</varname> property "
-"is to use JSONB functions and operators:"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
commit b9de4ae6113de6e86b85191abc6fcd7d2155a1a0
Date:   Tue Nov 28 22:58:11 2023 -0500
    Change berries to test against GEOS 3.13 (main branch of geos)
diff --git a/ci/berrie/configs.sh b/ci/berrie/configs.sh
index f47b1145d..5735eb3eb 100644
--- a/ci/berrie/configs.sh
+++ b/ci/berrie/configs.sh
@@ -1,5 +1,5 @@
 export WORKSPACE=/home/jenkins/workspace
-export GEOS_VER=3.12.0
+export GEOS_VER=3.13
 export OS_BUILD=32
 export PG_VER=15
diff --git a/ci/berrie64/configs.sh b/ci/berrie64/configs.sh
index 09ce6af01..b62b6988b 100644
--- a/ci/berrie64/configs.sh
+++ b/ci/berrie64/configs.sh
@@ -1,5 +1,5 @@
 export OS_BUILD=64
 export PG_VER=16
commit 9a7f57268d92570955255a33b8e6f497fdfce97d
Date:   Tue Nov 28 22:56:01 2023 -0500
    Fix ST_LargestEmptyCircle query, and remove the ST_AsText since we aren't showing the output
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 5c7f6fcc9..97e02c279 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1668,8 +1668,8 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
         <title>Examples</title>
 <programlisting>SELECT radius,
-       ST_AsText(center) AS center,
-       ST_AsText(nearest) AS nearest
+      center,
+      nearest
   FROM ST_LargestEmptyCircle(
         'MULTILINESTRING (
           (10 100, 60 180, 130 150, 190 160),
@@ -1686,13 +1686,14 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
     </informalfigure>
+       center,
+       nearest
-         St_Collect(
-           'MULTIPOINT ((70 50), (60 130), (130 150), (80 90))',
-           'POLYGON ((90 190, 10 100, 60 10, 190 40, 120 100, 190 180, 90 190))'),
+         ST_Collect(
+           'MULTIPOINT ((70 50), (60 130), (130 150), (80 90))'::geometry,
+           'POLYGON ((90 190, 10 100, 60 10, 190 40, 120 100, 190 180, 90 190))'::geometry),
+           0,
        );</programlisting>
     <informalfigure>
Summary of changes:
 ci/berrie/configs.sh                |   2 +-
 ci/berrie64/configs.sh              |   2 +-
 doc/po/templates/postgis-manual.pot | 118 ++++++++++++++++++++----------------
 doc/reference_processing.xml        |  17 +++---
 4 files changed, 76 insertions(+), 63 deletions(-)
hooks/post-receive
