[PostGIS] #5572: ST_Difference drops z-dimension on empty result
PostGIS trac at osgeo.org
Wed Nov 29 14:09:49 PST 2023
  Reporter:  lkajan      |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  3.4.x
Resolution:  worksforme  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => worksforme
 * milestone:  PostGIS 3.3.6 => PostGIS GEOS
Comment:
 Works for me too on GEOS 3.12.2dev LINESTRING Z EMPTY
 Going to close this out as GEOS.
 Ikajan your GEOS is a very old micro.  The latest release GEOS for 3.9 is
 3.9.5 https://libgeos.org/usage/download/.  If you can upgrade that that
 would be the best.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5572#comment:3>
