[PostGIS] #5630: CG_Visibility crash
PostGIS trac at osgeo.org
Wed Nov 29 15:33:50 PST 2023
 Reporter:  robe     |      Owner:  lbartoletti
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.5.0
Component:  sfcgal   |    Version:  master
 Keywords:           |
 Testing with SFCGAL 1.5.0
 POSTGIS="3.5.0dev 3.4.0rc1-818-g6c2e935b6" [EXTENSION] PGSQL="160"
 GEOS="3.12.1-CAPI-1.18.1" (compiled against GEOS 3.13.0) SFCGAL="SFCGAL
 1.5.0, CGAL 5.6, BOOST 1.78.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj
 DATABASE_PATH=C:\ming64gcc81\projects\proj\rel-
 proj-8.2.1w64gcc81/share/proj/proj.db" LIBXML="2.9.14" LIBJSON="0.12"
 LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"    PostgreSQL 16.0 on
 x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-seh-rev0, Built by
 MinGW-W64 project) 8.1.0, 64-bit
 SELECT CG_Visibility('POLYGON((24.2222222 40,24.183792760806462
 39.609819355967744,24.069981265022573 39.23463313526982,23.88516142460509
 38.8888595339608,23.636435762373097 38.58578643762691,23.333362666039207
 38.33706077539491,22.98758906473018 38.15224093497743,
 22.612402844032257 38.038429439193536,22.2222222 38,21.832041555967745
 38.038429439193536,21.45685533526982 38.15224093497743,21.1110817339608
 38.33706077539491,20.808008637626905 38.58578643762691,20.55928297539491
 38.8888595339608,20.37446313497743 39.23463313526982,
 20.26065163919354 39.609819355967744,20.2222222 40,20.26065163919354
 40.390180644032256,20.37446313497743 40.76536686473018,20.55928297539491
 41.1111404660392,20.808008637626905 41.41421356237309,21.111081733960795
 41.66293922460509,21.45685533526982 41.84775906502257,21.832041555967745
 41.96157056080646,22.2222222 42,
 22.612402844032257 41.961570560806464,
 22.98758906473018 41.84775906502257,
 23.333362666039204 41.66293922460509,23.636435762373097 41.41421356237309
 ,23.88516142460509 41.1111404660392
 ,24.069981265022573 40.76536686473018
 ,24.183792760806462 40.390180644032256,24.2222222 40))'::geometry
 ,       'POINT Z (-10 60 1)'::geometry)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5630>
