[PostGIS] #5628: ST_IsSimple crash on empty coordinate MULTIPOINT
PostGIS trac at osgeo.org
Wed Nov 29 16:58:53 PST 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  3.4.x
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 3.4.2 => PostGIS GEOS
Old description:
> SELECT ST_IsSimple( ST_GeomFromText('MULTIPOINT(EMPTY,2 1,2 4, 4
> 5)',4326) )  As result;
> Tested with PostgreSQL 16.0 on x86_64-w64-mingw32, compiled by gcc.exe
> (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
> POSTGIS="3.5.0dev 3.4.0rc1-818-g6c2e935b6" [EXTENSION] PGSQL="160"
> GEOS="3.13.0dev-CAPI-1.18.0"
> and
> GEOS="3.12.1-CAPI-1.18.1" (compiled against GEOS 3.13.0)
New description:
 SELECT ST_IsSimple( ST_GeomFromText('MULTIPOINT(EMPTY,2 1,2 4, 4 5)',4326)
 )  As result;
 and
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5628#comment:3>
