[SCM] PostGIS branch master updated. 3.4.0rc1-822-gf4de226cb
Wed Nov 29 19:00:33 PST 2023
the project "PostGIS".
       via  f4de226cb578ea9b23beb45088888c8aa71c21b4 (commit)
      from  c7d5374018eb17e6cd1fcdddddb3afdd5742e6af (commit)
revisions in full, below.
commit f4de226cb578ea9b23beb45088888c8aa71c21b4
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Nov 29 21:48:38 2023 -0500
    Garden test changes
    - Add check for POINT EMPTY within MULTIPOINT
    - Add Nan coordinates geometries
    - Remove tests we know are failing currently ST_RemoveRepeatedPoints
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 0c642a3f3..9f15c8e49 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -13,7 +13,7 @@
 	<xsl:output method="text" />
 	<xsl:variable name='testversion'>3.5.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
+	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable CG_Visibility CG_YMonotonePartition ST_RemoveRepeatedPoints ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
@@ -297,6 +297,26 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
 		'0104000020E6100000050000000101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F'::geometry AS the_geom )
 		</pgis:gset>
+		<pgis:gset ID="Multipoint with Empty coordinates" GeometryType="MULTIPOINT" createtable="false">
+		(SELECT ST_GeomFromText('MULTIPOINT(EMPTY,2 1,2 4, 4 5)',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Linestring Z with Nan coordinates" GeometryType="LINESTRINGZ" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING Z (1 2 NaN,3 4 10,5 6 NaN)',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Linestring M with Nan coordinates" GeometryType="LINESTRINGM" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING M (1 2 NaN,3 4 10,5 6 NaN)',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Linestring ZM with Nan coordinates" GeometryType="LINESTRINGZM" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING ZM (1 2 3 NaN,3 4 10 5,5 6 NaN NaN)',4326) As the_geom)
+		</pgis:gset>
+		</pgis:gset>
 	<!-- TODO: Finish off MULTI list -->
 	</pgis:gardens>
 	<!--This is just a placeholder to hold geometries that will crash server when hitting against some functions
Summary of changes:
 doc/xsl/postgis_gardentest.sql.xsl | 22 +++++++++++++++++++++-
 1 file changed, 21 insertions(+), 1 deletion(-)
hooks/post-receive
