[SCM] PostGIS branch master updated. 3.4.0rc1-824-ge85cd1052
Thu Nov 30 14:50:41 PST 2023
the project "PostGIS".
       via  e85cd10523ac7cd5e9ebe34c45f3317e9a19fe32 (commit)
      from  19f290f2396d156f8398d8a5cea48b4c6c8ee6c8 (commit)
revisions in full, below.
commit e85cd10523ac7cd5e9ebe34c45f3317e9a19fe32
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Nov 30 14:50:06 2023 -0800
    Handle EMPTY member of collections in PIP cache, references #5627
diff --git a/postgis/lwgeom_functions_analytic.c b/postgis/lwgeom_functions_analytic.c
index aae248c1c..e1f94b6c9 100644
--- a/postgis/lwgeom_functions_analytic.c
+++ b/postgis/lwgeom_functions_analytic.c
@@ -860,6 +860,9 @@ int point_in_multipolygon(LWMPOLY *mpolygon, LWPOINT *point)
 	POSTGIS_DEBUG(2, "point_in_polygon called.");
+	/* empty is not within anything */
+	if (lwpoint_is_empty(point)) return -1;
 	getPoint2d_p(point->point, 0, &pt);
 	/* assume bbox short-circuit has already been attempted */
diff --git a/postgis/lwgeom_rtree.c b/postgis/lwgeom_rtree.c
index 2aabb1dbb..efa2b3523 100644
--- a/postgis/lwgeom_rtree.c
+++ b/postgis/lwgeom_rtree.c
@@ -590,6 +590,9 @@ point_in_multipolygon_rtree(RTREE_NODE **root, int polyCount, int *ringCounts, L
 	POSTGIS_DEBUGF(2, "point_in_multipolygon_rtree called for %p %d %p.", root, polyCount, point);
 	pt = getPoint2d_cp(point->point, 0);
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 8fcc885e3..273695cae 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1509,3 +1509,11 @@ SELECT '#5320', ST_SimplifyPreserveTopology('0106000020E864000001000000010300000
 DROP PROCEDURE IF EXISTS p_force_parellel_mode(text);
 SELECT '#5378', ST_SRID( ST_Buffer(ST_GeomFromText('POINT(-94 29.53)', 4269)::geography, 12)::geometry );
+SELECT '#5627' AS ticket, bool_and(ST_Intersects(
+    'MULTIPOINT(EMPTY,(-378 574))'::geometry,
+    geom))
+FROM (VALUES
+    ('MULTIPOLYGON(((-357 477,-392 574,-378 574,-357 477)))'::geometry),
+    ('MULTIPOLYGON(((-357 477,-392 574,-378 574,-357 477)))'::geometry))
+    AS geoms(geom);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 145994491..a701e6d6b 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -468,3 +468,4 @@ ERROR:  Line has no points
 ERROR:  Geometry contains invalid coordinates
 #5378|4269
+#5627|t
Summary of changes:
 postgis/lwgeom_functions_analytic.c | 3 +++
 postgis/lwgeom_rtree.c              | 3 +++
 regress/core/tickets.sql            | 8 ++++++++
 regress/core/tickets_expected       | 1 +
 4 files changed, 15 insertions(+)
hooks/post-receive
