[postgis-tickets] [PostGIS] #5559: Just noticed manual-dev is not accessible
PostGIS trac at osgeo.org
Sun Oct 1 01:12:16 PDT 2023
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:  cjmayo
Comment (by strk):
 I've downloaded the index.html from chunked html published on postgis.net
 to test locally and I confirm that even when loaded from filesystem the
 page shows blank.
 I'm running some diffs to find out why.
 The only diff I see is that the online version has this:
 9d8
 <     <script src="ga.js" type="text/javascript"/>
 43,50d41
 <             <h2 class="subtitle">
 <               <sub>
 < DEV (<span class="emphasis"><em>
 < Fri 29 Sep 2023 08:04:39 AM UTC rev. c65bbfb </em></span>
 < )</sub>
 <             </h2>
 <           </div>
 <           <div>
 Maybe it is the google analytics breaking things (didn't someone recently
 mention we were not doing google analytics anymore?)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5559#comment:12>
