[postgis-tickets] [PostGIS] #5562: Remove hard-coded use of Google Analytics from repository
PostGIS trac at osgeo.org
Sun Oct 1 01:37:14 PDT 2023
 Reporter:  strk                   |      Owner:  strk
     Type:  task                   |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.5.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:  documentation          |
 At the moment a couple of makefile targets produce html which use
 javascript to report page visits to Google. I think we should replace them
 with some generic way to specify custom scripts to include in the HTML
 output.
 Doing so would simplify the scripts becuase we would not need separate
 targets for "chunked-html-web" and "chunked-html-web-mobile" as the only
 difference between those targets and "chunked-html" is the injection of
 different scripts/css.
 It will also be possible to switch between services without the need to
 change build scripts, for example to use an OSGeo provided analytics
 service ( see https://trac.osgeo.org/osgeo/ticket/2830 )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5562>
