[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-654-g04f10aeaa
Sun Oct 1 02:06:41 PDT 2023
the project "PostGIS".
       via  04f10aeaae4e70dfc472afb481dcf9fab131dc66 (commit)
      from  acea65beac6b3cef78ff0fcd2457fb8cb0b4fe96 (commit)
revisions in full, below.
commit 04f10aeaae4e70dfc472afb481dcf9fab131dc66
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Oct 1 11:06:02 2023 +0200
    Allow passing user flags to xsltproc, drop chunked-html-web target
    References #5562
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 8df679511..dd68786c1 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -395,28 +395,16 @@ chunked-html: $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css
 $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
 		$(XSLTPROC_CHUNKED_HTML_OPTS) \
+		$(XSLTPROCFLAGS) \
 		--output $(dir $@) \
 		$(CHUNK_HTML_DOCBOOK_XSL) \
-chunked-html-web: $(html_builddir)/postgis-web$(DOCSUFFIX)/docbook.css
-$(html_builddir)/postgis-web$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile
-	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
-		$(XSLTPROC_CHUNKED_HTML_OPTS) \
-		--output $(dir $@) \
-		--stringparam html.script ga.js \
-		$(CHUNK_HTML_DOCBOOK_XSL) \
+# TODO: drop this, replace with a generic CSS handling both mobile and # desktop
 HTML_BITS = $(wildcard html/*.html)
 chunked-html-web-mobile: $(html_builddir)/postgis-web-mobile$(DOCSUFFIX)/docbook.css
 $(html_builddir)/postgis-web-mobile$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile
+	$(MAKE) chunked-html
 	$(PERL) -pi -e 's/<head>/<head><meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">/g' $(HTML_BITS)
 html: $(html_builddir)/postgis$(DOCSUFFIX).html
diff --git a/doc/README b/doc/README
index 55f41c0ed..d08d9afb8 100644
--- a/doc/README
+++ b/doc/README
@@ -29,6 +29,9 @@ Make targets
 ``make chunked-html``
   generates a separate html file for every chapter or section break
+  You can use CHUNKED_HTML_USER_OPTS environment variable to tweak
+  the output, for example:
+  > make chunked-html XSLTPROCFLAGS="--stringparam html.script custom.js
 ``make pdf``
   generates a single PDF file with the PostGIS version as a filename
Summary of changes:
 doc/Makefile.in | 18 +++---------------
 doc/README      |  3 +++
 2 files changed, 6 insertions(+), 15 deletions(-)
hooks/post-receive
