[postgis-tickets] [PostGIS] #5562: Remove hard-coded use of Google Analytics from repository
PostGIS trac at osgeo.org
Sun Oct 1 03:10:32 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  task                   |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.5.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:  documentation
Comment (by strk):
 There's no more Makefile rule to explicitly use the ga.js file.
 That file entered the codebase in 2018 (by Paul) and was never modified.
 We've been using it ONLY for the chunked-html output so far, I don't know
 where is the data nor if we can download it for reuse in another system,
 so I'd leave the next steps to whoever knows about those details.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5562#comment:2>
