[postgis-tickets] [PostGIS] #5559: chunked-html-web renders blank (google analytics)
PostGIS trac at osgeo.org
Mon Oct 2 01:37:11 PDT 2023
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  blocker        |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:  cjmayo
Comment (by strk):
 For the record: I was told that the problem with the <script> tag was that
 XHTML5 required a closing tag (</script>) which is evidently not being
 done by our use of xsltproc and
 http://cdn.docbook.org/release/xsl/current/xhtml5/docbook.xsl XSL.
 Whether this is a bug in the docbook.xsl file or in xsltproc is out of
 scope at the moment, but shall we ever need to use `--stringparam
 html.script` this problem will need to be solved.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5559#comment:22>
