[postgis-tickets] [PostGIS] #5560: Debbie's PostGIS_Make_Dist should only run for main repo and only for stable/master branches
PostGIS trac at osgeo.org
Mon Oct 2 02:43:07 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by strk):
 I was thinking it would not be bad to have Debbie publish docs pushed to a
 "docs-staging" or similar named branch into a well-known URL that we could
 use to check effects of some docs changes
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5560#comment:2>
