[postgis-tickets] [PostGIS] #5545: Postgis upgrade from 3.2.3 to 3.3.2 failing on create or update function st_orderingequals
PostGIS trac at osgeo.org
Fri Oct 6 08:15:33 PDT 2023
st_orderingequals
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  pgextwlist
Comment (by strk):
 Note that if you're looking for a workaround, uninstalling any raster
 object from the database could be done via the script uninstaller, which
 should be, for 3.2, installed in `$(pg_config
 --sharedir)/contrib/postgis-3.2/uninstall_rtpostgis.sql`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5545#comment:13>
