[postgis-tickets] [PostGIS] #5568: Postgis Topology "mixed face labeling in ring | -267 | [NULL]"
PostGIS trac at osgeo.org
Sun Oct 8 01:33:29 PDT 2023
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.1
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Description changed by Lars Aksel Opsahl:
Old description:
> When running data through https://gitlab.com/nibioopensource/resolve-
> overlap-and-gap and checked the result by using ValidateTopology, we
> found error "mixed face labeling in ring" error for area that we missed
> data for in the result dataset.
> If you run ValidateTopology after running the attached file
> mixed_topo_error.sql no errors are found.
> SELECT * FROM topology.ValidateTopology('test_topo');
>  error | id1 | id2
> (0 rows)
> Then we add a new linestring with out any error
> SELECT topogeo_addlinestring FROM
> topology.TopoGeo_addLinestring('test_topo','0102000020A21000000200000084CBFA5C7A7824405CC705259CEE4D407A6873CA73782440DE38B01D9CEE4D40',0);
>                    269
> But if we now run topo validation again we see the error
> NOTICE:  00000: Checking for coincident nodes
> LOCATION:  exec_stmt_raise, pl_exec.c:3862
> NOTICE:  00000: Checking for edges crossing nodes
> NOTICE:  00000: Checking for invalid or not-simple edges
> NOTICE:  00000: Checking for crossing edges
> NOTICE:  00000: Checking for edges start_node mismatch
> NOTICE:  00000: Checking for edges end_node mismatch
> NOTICE:  00000: Checking for faces without edges
> NOTICE:  00000: Checking edge linking
> NOTICE:  00000: Building edge rings
> NOTICE:  00000: Found 115 rings, 108 valid shells, 6 valid holes
>             error            | id1  |  id2
> (1 row)
> Here is last server I tested on
> PostgreSQL 12.6 (Ubuntu 12.6-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu,
> compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
> POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.10.1-CAPI-1.16.0"
> SFCGAL="1.3.7" PROJ="8.2.0 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
> DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.10" LIBJSON="0.13.1"
> LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
New description:
 overlap-and-gap and checked the result by using ValidateTopology, we found
 error "mixed face labeling in ring" error for area that we missed data for
  error | id1 | id2
 (0 rows)
                    269
             error            | id1  |  id2
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5568#comment:1>
