[postgis-tickets] [PostGIS] #5568: Postgis Topology "mixed face labeling in ring | -267 | [NULL]"
PostGIS trac at osgeo.org
Mon Oct 9 03:46:41 PDT 2023
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.0.10
 Component:  topology           |    Version:  3.0.x
Resolution:                     |   Keywords:
Comment (by strk):
 Ok the issue is in the way we determine if an edge among the edges
 intersecting the new face is contained or not in the new face.
 The way we do this is as follows:
  1. We get an interior point of the edge
  2. we check with ptarray_contains_point if the new shell contains that
 point
 In our case I bet the "interior point" on the very-close external edge
 ends up being internal to the new face, as step 1 is a "constructive"
 method, and thus is subject to drifts. The current code (
 _lwt_GetInteriorEdgePoint ) makes a best effort at finding an existing
 vertex, to avoid the constructtive method, but in this case it evidently
 fails in doing so. Indeed the edge 160 in the original testcase is formed
 by only 2 vertices. Edge 161 is the one that's really inside the new face,
 but edge 160 is erroneously found to be inside due to this constructive
 interpolation.
 I'm not sure what a good fix would be, but the goal here would be avoiding
 the interpolation. Maybe using Covers from GEOS against the whole line,
 when the line has less than 3 distinct vertices could be a solution.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5568#comment:9>
