[postgis-tickets] [PostGIS] #5569: postgis_restore doesn't strip some old functions
PostGIS trac at osgeo.org
Mon Oct 16 03:14:31 PDT 2023
 Reporter:  kesar                  |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  low                    |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:  postgis_restore        |
 we are migrating an old database to a new server and doing the HARD
 UPGRADE (as instructed in
 http://postgis.net/docs/manual-3.4/postgis_administration.html#hard_upgrade)
 from Postgis 2.1.8 to 3.4.
 Seems that some deprecated/old functions are not stripped by
 ''postgis_restore'':
 CREATE FUNCTION pgis_abs_in(cstring) RETURNS pgis_abs
     LANGUAGE c IMMUTABLE STRICT
     AS '$libdir/postgis-2.1', 'pgis_abs_in';
 CREATE FUNCTION pgis_abs_out(pgis_abs) RETURNS cstring
     AS '$libdir/postgis-2.1', 'pgis_abs_out';
 CREATE FUNCTION pgis_geometry_accum_finalfn(pgis_abs) RETURNS geometry[]
     LANGUAGE c
     AS '$libdir/postgis-2.1', 'pgis_geometry_accum_finalfn';
 CREATE FUNCTION pgis_geometry_accum_transfn(pgis_abs, geometry) RETURNS
 pgis_abs
     LANGUAGE c
     AS '$libdir/postgis-2.1', 'pgis_geometry_accum_transfn';
 CREATE FUNCTION pgis_geometry_collect_finalfn(pgis_abs) RETURNS geometry
     LANGUAGE c
     AS '$libdir/postgis-2.1', 'pgis_geometry_collect_finalfn';
 CREATE FUNCTION pgis_geometry_makeline_finalfn(pgis_abs) RETURNS geometry
     LANGUAGE c
     AS '$libdir/postgis-2.1', 'pgis_geometry_makeline_finalfn';
 CREATE FUNCTION pgis_geometry_polygonize_finalfn(pgis_abs) RETURNS
 geometry
     LANGUAGE c
     AS '$libdir/postgis-2.1', 'pgis_geometry_polygonize_finalfn';
 CREATE FUNCTION pgis_geometry_union_finalfn(pgis_abs) RETURNS geometry
     LANGUAGE c
     AS '$libdir/postgis-2.1', 'pgis_geometry_union_finalfn';
 CREATE FUNCTION st_askml(geog geography, maxdecimaldigits integer DEFAULT
 15) RETURNS text
     LANGUAGE sql IMMUTABLE STRICT
     AS $_$SELECT _ST_AsKML(2, $1, $2, null)$_$;
 CREATE FUNCTION st_askml(geom geometry, maxdecimaldigits integer DEFAULT
 15) RETURNS text
     AS $_$ SELECT _ST_AsKML(2, ST_Transform($1,4326), $2, null); $_$;
 CREATE FUNCTION st_dwithin(geography, geography, double precision) RETURNS
 boolean
     AS $_$SELECT $1 && _ST_Expand($2,$3) AND $2 && _ST_Expand($1,$3) AND
 _ST_DWithin($1, $2, $3, true)$_$;
 It also tries to add comments to non-existent functions and constraints to
 already existing Postgis 3.4 tables.
 Here are the error messages:
 ERROR:  could not access file "$libdir/postgis-2.1": No such file or
 directory
 ERROR:  function public.pgis_abs_in(cstring) does not exist
 directory
 ERROR:  function public.pgis_abs_out(pgis_abs) does not exist
 directory
 ERROR:  function public.pgis_geometry_accum_finalfn(pgis_abs) does not
 exist
 directory
 ERROR:  function public.pgis_geometry_accum_transfn(pgis_abs, geometry)
 does not exist
 directory
 ERROR:  function public.pgis_geometry_collect_finalfn(pgis_abs) does not
 exist
 directory
 ERROR:  function public.pgis_geometry_makeline_finalfn(pgis_abs) does not
 exist
 directory
 ERROR:  function public.pgis_geometry_polygonize_finalfn(pgis_abs) does
 not exist
 directory
 ERROR:  function public.pgis_geometry_union_finalfn(pgis_abs) does not
 exist
 ERROR:  function st_asgeojson(integer, geography, integer, integer) does
 not exist
 ERROR:  function st_asgeojson(integer, geometry, integer, integer) does
 not exist
 ERROR:  function st_askml(integer, geography, integer, text) does not
 exist
 ERROR:  function st_count(text, text, boolean) does not exist
 ERROR:  function st_count(text, text, integer, boolean) does not exist
 ERROR:  function st_force3d(geometry) does not exist
 ERROR:  function st_force3dm(geometry) does not exist
 ERROR:  function st_force3dz(geometry) does not exist
 ERROR:  function st_force4d(geometry) does not exist
 ERROR:  function st_histogram(text, text, integer, integer, boolean) does
 not exist
 ERROR:  function st_histogram(text, text, integer, boolean, integer,
 ERROR:  function st_histogram(text, text, integer, integer, double
 precision[], boolean) does not exist
 double precision[], boolean) does not exist
 ERROR:  function st_quantile(text, text, integer, double precision[]) does
 not exist
 ERROR:  function st_quantile(text, text, integer, boolean, double
 precision[]) does not exist
 ERROR:  function st_summarystats(text, text, boolean) does not exist
 ERROR:  function st_summarystats(text, text, integer, boolean) does not
 exist
 ERROR:  function validatetopology(character varying) does not exist
 ERROR:  multiple primary keys for table "layer" are not allowed
 ERROR:  relation "layer_schema_name_table_name_feature_column_key" already
 exists
 ERROR:  relation "topology_name_key" already exists
 ERROR:  multiple primary keys for table "topology" are not allowed
 ERROR:  rule "geometry_columns_delete" for relation "geometry_columns"
 already exists
 ERROR:  rule "geometry_columns_insert" for relation "geometry_columns"
 already exists
 ERROR:  rule "geometry_columns_update" for relation "geometry_columns"
 already exists
 ERROR:  trigger "layer_integrity_checks" for relation "layer" already
 exists
 ERROR:  constraint "layer_topology_id_fkey" for relation "layer" already
 exists
 ERROR:  multiple primary keys for table "spatial_ref_sys" are not allowed
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5569>
