[postgis-tickets] [PostGIS] #5573: Enable postgis_restore based upgrade tests in CI
PostGIS trac at osgeo.org
Tue Oct 17 07:39:57 PDT 2023
  Reporter:  strk       |      Owner:  robe
      Type:  task       |     Status:  new
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:
Resolution:             |   Keywords:
Comment (by strk):
 We're now testing unpackaged upgrades,see:
 https://woodie.osgeo.org/repos/30/pipeline/1321/7#L15378
 Testing dumprestore now could be done either passing the --dumprestore
 switch in RUNTESTFLAGS from the outside of check_all_upgrades.sh or by
 making that script explicitly test the dumprestore in addition to the soft
 upgrade. Given extension-based --dumprestore is probably not that
 interesting I'm leaning toward the second choice, maybe with a --skip-
 hard-upgrade to eventually avoid that if it fails (we know it fails)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5573#comment:5>
