[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-692-g02aa9ed58
Tue Oct 17 11:54:22 PDT 2023
the project "PostGIS".
       via  02aa9ed587319440529058426c0a8e10a7ea67bc (commit)
       via  0fdfb522e281674f41a79646a11a9a37f8f686f2 (commit)
      from  d9a7a30ed20ba0b747805b9fd95e0f2ace838b2b (commit)
revisions in full, below.
commit 02aa9ed587319440529058426c0a8e10a7ea67bc
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 20:54:01 2023 +0200
    Remove needlessly hard-coded skip signatures
    See https://woodie.osgeo.org/repos/30/pipeline/1323/7#L2093
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.pl.in
index ec1ccf0fb..dfbbdfad5 100644
--- a/utils/postgis_restore.pl.in
+++ b/utils/postgis_restore.pl.in
@@ -563,7 +563,6 @@ COMMENT FUNCTION addrasterconstraints(rasttable name, rastcolumn name, VARIADIC
 COMMENT FUNCTION droprasterconstraints(rastschema name, rasttable name, rastcolumn name, VARIADIC constraints text[])
 COMMENT FUNCTION lockrow(text, text, text, text, timestamp without time zone)
 COMMENT FUNCTION lockrow(text, text, text, timestamp without time zone)
-COMMENT FUNCTION postgis_extensions_upgrade()
 COMMENT FUNCTION st_clusterkmeans(geom geometry, k integer)
 COMMENT FUNCTION st_concavehull(param_geom geometry, param_pctconvex double precision, param_allow_holes boolean)
 COMMENT FUNCTION st_difference(geom1 geometry, geom2 geometry)
@@ -615,7 +614,6 @@ COMMENT FUNCTION st_subdivide(geom geometry, maxvertices integer)
 COMMENT FUNCTION st_sum4ma(matrix double precision[], nodatamode text, VARIADIC args text[])
 COMMENT FUNCTION st_sum4ma(value double precision[], pos integer[], VARIADIC userargs text[])
 COMMENT FUNCTION st_symdifference(geom1 geometry, geom2 geometry)
-COMMENT FUNCTION st_unaryunion(geometry)
 COMMENT FUNCTION st_valuecount(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision, OUT value double precision, OUT count integer)
 COMMENT FUNCTION st_valuecount(rastertable text, rastercolumn text, nband integer, searchvalues double precision[], roundto double precision, OUT value double precision, OUT count integer)
 COMMENT FUNCTION st_valuecount(rastertable text, rastercolumn text, searchvalues double precision[], roundto double precision, OUT value double precision, OUT count integer)
@@ -642,21 +640,13 @@ FUNCTION jsonb(geometry)
 FUNCTION json(geometry)
-FUNCTION postgis_extensions_upgrade()
 FUNCTION _st_aspect4ma(double precision[], integer[], text[])
-FUNCTION st_clusterkmeans(geometry, integer)
 FUNCTION st_concavehull(geometry, double precision, boolean)
 FUNCTION _st_convertarray4ma(double precision[])
-FUNCTION st_difference(geometry, geometry)
 FUNCTION st_distinct4ma(double precision[], integer[], text[])
 FUNCTION st_distinct4ma(double precision[], text, text[])
-FUNCTION st_force3d(geometry)
-FUNCTION st_force3dm(geometry)
-FUNCTION st_force3dz(geometry)
-FUNCTION st_force4d(geometry)
 FUNCTION _st_grayscale4ma(double precision[], integer[], text[])
 FUNCTION _st_hillshade4ma(double precision[], integer[], text[])
-FUNCTION st_intersection(geometry, geometry)
 FUNCTION st_invdistweight4ma(double precision[], integer[], text[])
 FUNCTION _st_mapalgebra(rastbandarg[], regprocedure, text, integer, integer, text, raster, double precision[], boolean, text[])
 FUNCTION st_mapalgebra(rastbandarg[], regprocedure, text, text, raster, integer, integer, text[])
@@ -683,14 +673,10 @@ FUNCTION st_setvalues(raster, integer, integer, integer, double precision[], dou
 FUNCTION _st_slope4ma(double precision[], integer[], text[])
 FUNCTION st_stddev4ma(double precision[], integer[], text[])
 FUNCTION st_stddev4ma(double precision[], text, text[])
-FUNCTION st_subdivide(geometry, integer)
 FUNCTION st_sum4ma(double precision[], integer[], text[])
 FUNCTION st_sum4ma(double precision[], text, text[])
-FUNCTION st_symdifference(geometry, geometry)
-FUNCTION st_tileenvelope(integer, integer, integer, geometry)
 FUNCTION _st_tpi4ma(double precision[], integer[], text[])
 FUNCTION _st_tri4ma(double precision[], integer[], text[])
-FUNCTION st_unaryunion(geometry)
 OPERATOR &&
 OPERATOR &&&
 OPERATOR &/&
commit 0fdfb522e281674f41a79646a11a9a37f8f686f2
Date:   Tue Oct 17 20:53:36 2023 +0200
    Fix `\1 better written as $1` perl warnings
diff --git a/utils/create_skip_signatures.pl b/utils/create_skip_signatures.pl
index 231ddae71..7db9885e7 100644
--- a/utils/create_skip_signatures.pl
+++ b/utils/create_skip_signatures.pl
@@ -200,7 +200,7 @@ while (<>)
 		my $origline = $_;
 		my $line = $origline;
-		$line =~ s/ *ALTER FUNCTION (.*) RENAME TO .*_deprecated_by_postgis_.*/\1/;
+		$line =~ s/ *ALTER FUNCTION (.*) RENAME TO .*_deprecated_by_postgis_.*/$1/;
 		handle_function_signature($line);
@@ -213,7 +213,7 @@ while (<>)
 		my $origline = $_;
-		$line =~ s/SELECT _postgis_drop_function_by_signature\('([^']*)'\);/\1/;
+		$line =~ s/SELECT _postgis_drop_function_by_signature\('([^']*)'\);/$1/;
Summary of changes:
 utils/create_skip_signatures.pl |  4 ++--
 utils/postgis_restore.pl.in     | 14 --------------
 2 files changed, 2 insertions(+), 16 deletions(-)
hooks/post-receive
