[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-694-ga4ac60f6d
Tue Oct 17 13:23:26 PDT 2023
the project "PostGIS".
       via  a4ac60f6d405b21f08f24021aeee20634eb63514 (commit)
      from  ef5a742b5b8dae8beae5ede0adaee90919e99069 (commit)
revisions in full, below.
commit a4ac60f6d405b21f08f24021aeee20634eb63514
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 22:22:46 2023 +0200
    Fix extraction of skip signatures from function with variadic args
    References #5576 in master branch (3.5.0dev)
diff --git a/utils/create_skip_signatures.pl b/utils/create_skip_signatures.pl
index 7db9885e7..9995d4127 100644
--- a/utils/create_skip_signatures.pl
+++ b/utils/create_skip_signatures.pl
@@ -75,15 +75,12 @@ sub strip_argument_names {
 		my $a = $_;
 		#print "  XXX arg: $a\n";
-		# If the arg is composed by multiple words
-		# drop the first, unless it's a reserved word
-		if ( $a =~ m/([^ ]*) (.*)/ )
+		# Drop all but reserved words from multi-word arg
+		while ( $a =~ m/^([^ ]*) (.*)/ )
-			unless ( $reserved_sql_word{$1} )
-				$a = $2;
-				#print "  XXX arg became: $a\n";
+			last if $reserved_sql_word{$1};
+			$a = $2;
+			#print "  XXX arg became: $a\n";
 		push @out, $a;
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.pl.in
index 906b0a684..f282608b4 100644
--- a/utils/postgis_restore.pl.in
+++ b/utils/postgis_restore.pl.in
@@ -637,10 +637,6 @@ DEFAULT topology id
 DOMAIN topoelement
 DOMAIN topoelementarray
 FK CONSTRAINT layer layer_topology_id_fkey
-FUNCTION addrasterconstraints(name, name, name, text[])
-FUNCTION addrasterconstraints(name, name, text[])
-FUNCTION droprasterconstraints(name, name, name, text[])
-FUNCTION droprasterconstraints(name, name, text[])
 FUNCTION jsonb(geometry)
 FUNCTION json(geometry)
 FUNCTION lockrow(text, text, text, text, timestamp without time zone)
@@ -654,11 +650,7 @@ FUNCTION _st_grayscale4ma(double precision[], integer[], text[])
 FUNCTION _st_hillshade4ma(double precision[], integer[], text[])
 FUNCTION st_invdistweight4ma(double precision[], integer[], text[])
 FUNCTION _st_mapalgebra(rastbandarg[], regprocedure, text, integer, integer, text, raster, double precision[], boolean, text[])
-FUNCTION st_mapalgebra(rastbandarg[], regprocedure, text, text, raster, integer, integer, text[])
-FUNCTION st_mapalgebra(raster, integer, raster, integer, regprocedure, text, text, raster, integer, integer, text[])
 FUNCTION st_mapalgebra(raster, integer, regprocedure, double precision[], boolean, text, text, raster, text[])
-FUNCTION st_mapalgebra(raster, integer, regprocedure, text, text, raster, integer, integer, text[])
-FUNCTION st_mapalgebra(raster, integer[], regprocedure, text, text, raster, integer, integer, text[])
 FUNCTION st_max4ma(double precision[], integer[], text[])
 FUNCTION st_max4ma(double precision[], text, text[])
 FUNCTION st_mean4ma(double precision[], integer[], text[])
@@ -669,8 +661,6 @@ FUNCTION st_mindist4ma(double precision[], integer[], text[])
 FUNCTION st_range4ma(double precision[], integer[], text[])
 FUNCTION st_range4ma(double precision[], text, text[])
 FUNCTION st_rastertoworldcoord(raster, integer, integer)
-FUNCTION _st_reclass(raster, reclassarg[])
-FUNCTION st_reclass(raster, reclassarg[])
 FUNCTION _st_roughness4ma(double precision[], integer[], text[])
 FUNCTION st_setvalues(raster, integer, integer, integer, double precision[], boolean[], boolean)
 FUNCTION _st_setvalues(raster, integer, integer, integer, double precision[], boolean[], boolean, double precision, boolean)
Summary of changes:
 utils/create_skip_signatures.pl | 13 +++++--------
 utils/postgis_restore.pl.in     | 10 ----------
 2 files changed, 5 insertions(+), 18 deletions(-)
hooks/post-receive
