[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-695-gcc1607004
Tue Oct 17 13:40:29 PDT 2023
the project "PostGIS".
       via  cc1607004b6b6ff6437b1e9a7708e1198c74af88 (commit)
      from  a4ac60f6d405b21f08f24021aeee20634eb63514 (commit)
revisions in full, below.
commit cc1607004b6b6ff6437b1e9a7708e1198c74af88
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 22:39:17 2023 +0200
    Fix restore of dumps with topology from 3.1
    References #5577 in master branch (3.5.0dev)
diff --git a/topology/topology_before_upgrade.sql.in b/topology/topology_before_upgrade.sql.in
index aa0c7252f..bf4104c0d 100644
--- a/topology/topology_before_upgrade.sql.in
+++ b/topology/topology_before_upgrade.sql.in
@@ -13,34 +13,20 @@
 -- argument names changed --
 -- we might want to take toTopoGeom one out before release since
 -- I don't think too many people installed the bad name
-SELECT NULL FROM _postgis_drop_function_by_signature('
-topology.toTopoGeom(Geometry, varchar, int, float8)
+SELECT _postgis_drop_function_by_signature('topology.toTopoGeom(Geometry, varchar, int, float8)');
 -- used to be in public, will now be moved to topology
-public.postgis_topology_scripts_installed()
+SELECT _postgis_drop_function_by_signature('public.postgis_topology_scripts_installed()');
 -- Removed in 2.2.0 when topology API moved to liblwgeom
-topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer)
-', '2.2.0');
+SELECT _postgis_drop_function_by_signature('topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer)', '2.2.0');
-topology._ST_AddFaceSplit(varchar, integer, integer, boolean)
-', '2.2.0');
+SELECT _postgis_drop_function_by_signature('topology._ST_AddFaceSplit(varchar, integer, integer, boolean)', '2.2.0');
 -- Added optional bbox parameter in 3.2.0
-topology.validatetopology(varchar)
-', '3.2.0');
+SELECT _postgis_drop_function_by_signature('topology.validatetopology(varchar)', '3.2.0');
 -- Merged the two function into one with both allowEdgeSplitting and setContainingFace parameters
 -- being optional (3.2.0)
-topology.AddNode(varchar, geometry)
-', '3.2.0');
-topology.AddNode(varchar, geometry, boolean, boolean)
-', '3.2.0');
+SELECT _postgis_drop_function_by_signature('topology.AddNode(varchar, geometry)', '3.2.0');
+SELECT _postgis_drop_function_by_signature('topology.AddNode(varchar, geometry, boolean, boolean)', '3.2.0');
diff --git a/utils/create_skip_signatures.pl b/utils/create_skip_signatures.pl
index 9995d4127..7d67fda0a 100644
--- a/utils/create_skip_signatures.pl
+++ b/utils/create_skip_signatures.pl
@@ -205,12 +205,12 @@ while (<>)
 	# Deprecated function signature using
 	# _postgis_drop_function_by_signature
 	# EXAMPLE: SELECT _postgis_drop_function_by_signature('pgis_geometry_union_finalfn(internal)');
-	elsif ( /SELECT _postgis_drop_function_by_signature\('[^']*'\);/ )
+	elsif ( /SELECT _postgis_drop_function_by_signature\('[^']*'/ )
 		my $origline = $_;
 		my $line = $origline;
-		$line =~ s/SELECT _postgis_drop_function_by_signature\('([^']*)'\);/$1/;
+		$line =~ s/.*SELECT _postgis_drop_function_by_signature\('([^']*)'.*/$1/;
 		handle_function_signature($line);
Summary of changes:
 topology/topology_before_upgrade.sql.in | 28 +++++++---------------------
 utils/create_skip_signatures.pl         |  4 ++--
 2 files changed, 9 insertions(+), 23 deletions(-)
hooks/post-receive
