[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-697-g01eed3748
Tue Oct 17 14:20:24 PDT 2023
the project "PostGIS".
       via  01eed3748c0995d31c9d8fb9f3f2b5120dfab3b4 (commit)
      from  5a8528e775d15538898d6483c81052ca1df72607 (commit)
revisions in full, below.
commit 01eed3748c0995d31c9d8fb9f3f2b5120dfab3b4
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 17 23:19:59 2023 +0200
    Properly drop st_quantile signatures deprecated in 3.1
    References #5579 in master branch (3.5.0dev)
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index 3f7ed38b7..3d75f71c0 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -277,28 +277,31 @@ SELECT _postgis_drop_function_by_signature('_st_summarystats(raster,int, boolean
 SELECT _postgis_drop_function_by_signature('_st_summarystats(text, text,integer, boolean, double precision)');
 -- remove TYPE quantile
-SELECT _postgis_drop_function_by_signature('st_quantile(raster, int, boolean, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_quantile(raster, int, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_quantile(raster, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, int, boolean, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, int, double precision, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, double precision, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, boolean, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_quantile(text, text, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, boolean, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
-SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, integer, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
-SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, integer, boolean, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, int, boolean, double precision, double precision[])');
 SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, int, double precision, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision, double precision[])');
-SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, integer, boolean, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_approxquantile(text, text, integer, double precision, double precision)', '3.1.0'); -- See https://trac.osgeo.org/postgis/ticket/5578
+SELECT _postgis_drop_function_by_signature('st_quantile(raster, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_quantile(raster, int, boolean, double precision[])');
 SELECT _postgis_drop_function_by_signature('_st_quantile(raster, int, boolean, double precision, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_quantile(raster, int, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_quantile(text, text, boolean, double precision)'); -- see https://trac.osgeo.org/postgis/ticket/5579
+SELECT _postgis_drop_function_by_signature('st_quantile(text, text, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_quantile(text, text, double precision)'); -- see https://trac.osgeo.org/postgis/ticket/5579
+SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, boolean, double precision[])');
 SELECT _postgis_drop_function_by_signature('_st_quantile(text, text, int, boolean, double precision, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, boolean, double precision)'); -- see https://trac.osgeo.org/postgis/ticket/5579
+SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, double precision[])');
+SELECT _postgis_drop_function_by_signature('st_quantile(text, text, int, double precision)'); -- see https://trac.osgeo.org/postgis/ticket/5579
 -- this cannot be drop until the quantile deprecated functions are gone
 DROP TYPE IF EXISTS quantile;
Summary of changes:
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in | 31 +++++++++++++++------------
 1 file changed, 17 insertions(+), 14 deletions(-)
hooks/post-receive
