[postgis-tickets] [PostGIS] #5569: postgis_restore doesn't strip 2.1 function signatures
PostGIS trac at osgeo.org
Tue Oct 17 23:45:28 PDT 2023
  Reporter:  kesar                  |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  low                    |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  postgis_restore
Comment (by strk):
 I found a way to test without having the dump:
 touch x;
 postgis_restore -v -L postgis21_manifest.txt x 2>&1 | grep KEEP
 we will not want any postgis object in the output.
 With the current code the left over are:
 KEEP: SHELLTYPE pgis_abs
 KEEP: FUNCTION pgis_abs_in(cstring)
 KEEP: FUNCTION pgis_abs_out(pgis_abs)
 KEEP: FUNCTION pgis_geometry_accum_finalfn(pgis_abs)
 KEEP: FUNCTION pgis_geometry_accum_transfn(pgis_abs, geometry)
 KEEP: FUNCTION pgis_geometry_collect_finalfn(pgis_abs)
 KEEP: FUNCTION pgis_geometry_makeline_finalfn(pgis_abs)
 KEEP: FUNCTION pgis_geometry_polygonize_finalfn(pgis_abs)
 KEEP: FUNCTION pgis_geometry_union_finalfn(pgis_abs)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5569#comment:13>
