[postgis-tickets] [PostGIS] #5569: postgis_restore doesn't strip 2.1 function signatures
PostGIS trac at osgeo.org
Wed Oct 18 02:29:38 PDT 2023
  Reporter:  kesar                  |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  low                    |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  postgis_restore
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"bc51b1a6dd813aeb1c253f23e2cee4c5a5099166/git"
 bc51b1a6/git]:
 {{{#!CommitTicketReference repository="git"
 revision="bc51b1a6dd813aeb1c253f23e2cee4c5a5099166"
 Simplify handling of comment signatures
 Always skip comments on skipped objects.
 Stop including now unneded comment signatures
 in the installed postgis_restore script, reducing
 its size by 65% (163k)
 In 3.4 branch (3.4.1dev):
   Closes #3078
   References #5569
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5569#comment:19>
