[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-700-g65c8de96d
Wed Oct 18 02:39:04 PDT 2023
the project "PostGIS".
       via  65c8de96d423196376f4bbca36e4351f4f13da82 (commit)
      from  a6d5ce0b58bdbd511192fbcd56166ff5ba3078a0 (commit)
revisions in full, below.
commit 65c8de96d423196376f4bbca36e4351f4f13da82
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 18 11:29:48 2023 +0200
    Drop deprecated pgis_abs based functions from <2.5 dumps
    References #5569 in master branch (3.5.0dev)
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index 168b9c120..7469567eb 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -171,9 +171,17 @@ SELECT _postgis_drop_function_by_signature('ST_AsBinary(text)'); -- deprecated i
 SELECT _postgis_drop_function_by_signature('postgis_uses_stats()'); -- deprecated in 2.0
 SELECT _postgis_drop_function_by_signature('ST_GeneratePoints(geometry, numeric)'); -- numeric -> integer
--- Old accum aggregate support type, removed in 2.5.0
--- See #4035
-DROP TYPE IF EXISTS pgis_abs CASCADE;
+-- Old accum aggregate support type, removed in 2.5.0 See #4035
+SELECT _postgis_drop_function_by_signature('pgis_abs_in(cstring)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_abs_out(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_accum_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_accum_transfn(pgis_abs, geometry)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_collect_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_makeline_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_polygonize_finalfn(pgis_abs)', '2.5.0');
+SELECT _postgis_drop_function_by_signature('pgis_geometry_union_finalfn(pgis_abs)', '2.5.0');
+DROP TYPE IF EXISTS pgis_abs CASCADE; -- TODO: use a _postgis_drop_type ?
 SELECT _postgis_drop_function_by_signature('st_astwkb(geometry, integer, bigint, bool, bool)'); -- temporarely introduced before 2.2.0 final
 SELECT _postgis_drop_function_by_signature('pgis_twkb_accum_transfn(internal, geometry, integer)'); -- temporarely introduced before 2.2.0 final
Summary of changes:
 postgis/postgis_after_upgrade.sql | 14 +++++++++++---
 1 file changed, 11 insertions(+), 3 deletions(-)
hooks/post-receive
