[postgis-tickets] [PostGIS] #5569: postgis_restore doesn't strip 2.1 function signatures
PostGIS trac at osgeo.org
Wed Oct 18 03:49:32 PDT 2023
  Reporter:  kesar                  |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  low                    |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  fixed                  |   Keywords:  postgis_restore
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"817e9d0e3cbe3f7a539f8386223bfbe1ef10dade/git"
 817e9d0e/git]:
 {{{#!CommitTicketReference repository="git"
 revision="817e9d0e3cbe3f7a539f8386223bfbe1ef10dade"
 Skip shelltype when type is skipped
 Closes #5569 in 3.4 branch (3.4.1dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5569#comment:24>
