[postgis-tickets] [PostGIS] #5581: ST_Project(geometry, float, float) is using longitudes as latitudes
PostGIS trac at osgeo.org
Wed Oct 18 04:46:49 PDT 2023
 Reporter:  TrippMadam  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  medium      |  Milestone:  PostGIS 3.4.1
Component:  postgis     |    Version:  3.4.x
 Keywords:              |
 When you use ST_Project() to project a new geometry point a distance and
 azimuth from an existing geometry point, the coordinates of the new point,
 which should be (lon,lat) are (lon,lon) instead. The version of the
 function that accepts geography points is okay, so as a workaround I am
 temporarily converting my geometry points to geography points and then
 back again after doing the ST_Project() operation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5581>
