[postgis-tickets] [PostGIS] #5584: PostGIS Upgrade Issue
PostGIS trac at osgeo.org
Thu Oct 19 09:49:29 PDT 2023
 Reporter:  rama     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  high     |  Milestone:  PostGIS PostgreSQL
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 I am facing an issue with PostGIS Upgrade from 2.5.0 to 3.3.3. Please
 check and help me out to fix the issue.
 Environment Details
 Os: Windows Environment (Windows 2016)
 Postgresql Version: 11
 Postgis Upgrade from 2.5.0 to 3.3.3
 Download and installation done from stack builder
 Current Version of Database and Postgis
   DATABASE_VERSION
  PostgreSQL 11.0, compiled by Visual C++ build 1914, 64-bit
 (1 row)
 POSTGIS_VERSION
  POSTGIS="2.5.0 r16836" [EXTENSION] PGSQL="110" GEOS="3.7.0-CAPI-1.11.0
 3.7.0" SFCGAL="1.3.2" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.4,
 released 2018/03/19 GDAL_DATA not found" LIBXML="2.7.8" LIBJSON="0.12"
 LIBPROTOBUF="1.2.1" TOPOLOGY RASTER
 (1 row)
 Command Execution Details
 ALTER EXTENSION postgis UPDATE TO "3.3.3";
 ALTER EXTENSION postgis_topology UPDATE TO "3.3.3";
 ALTER EXTENSION postgis_sfcgal UPDATE TO "3.3.3";
 ALTER EXTENSION postgis_tiger_geocoder UPDATE TO "3.3.3";
 ALTER EXTENSION address_standardizer UPDATE TO "3.3.3";
 ALTER EXTENSION pgrouting UPDATE TO "3.5.0";
 ALTER EXTENSION pointcloud UPDATE TO "1.2.4";
 ALTER EXTENSION pointcloud_postgis UPDATE TO "1.2.4";
 ALTER EXTENSION ogr_fdw UPDATE TO "1.1";
 execute update command for Postgis twice while moving from 2.* to 3.*
 SELECT postgis_extensions_upgrade();
 ERROR message:
 WARNING:  unpackaging raster
 WARNING:  PostGIS Raster functionality has been unpackaged
 HINT:  type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
 After upgrading, if you want to drop raster, run: DROP EXTENSION
 postgis_raster;
 ERROR:  could not load library "R:/Database/11/lib/postgis-3.dll": The
 specified procedure could not be found.
 postgis_raster;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5584>
