[postgis-tickets] [PostGIS] #5580: ST_3DIntersects fails when encouting a GEOMETRYCOLLECTION with an empty geometry
PostGIS trac at osgeo.org
Thu Oct 19 23:42:09 PDT 2023
geometry
  Reporter:  Wenjing  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.4.1
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Description changed by Wenjing:
Old description:
> Consider this query:
> SELECT
> ST_Intersects(a1, a2)
> FROM ST_GeomFromText('GEOMETRYCOLLECTION(POINT EMPTY, POINT (0 0))') As
> a1
> , ST_GeomFromText('POINT (0 0)') As a2;
> --expected{t}
> When using the 2D Intersects function in this situation, the expected
> result is true because POINT(0 0) is the two geometries' intersection.
> PostGIS returns true.
> But consider its 3D version:
> SELECT
> ST_3DIntersects(a1, a2)
> FROM ST_GeomFromText('GEOMETRYCOLLECTION Z (POINT Z EMPTY, POINT Z (0 0
> 0))') As a1
> , ST_GeomFromText('POINT Z (0 0 0)') As a2;
> --expected{t}; actual{f}
> POINT Z (0 0 0) is the two geometries' intersection. So the excepted
> result of 3DIntersects is true.
> But the 3DIntersects function doesn't consider they intersect only when
> inserting an empty geometry before this point.
New description:
 SELECT
 0))') As a1
 --excepted{t}; actual{f}
 Postgis produces a result of false, but I expected it to produce true. I
 think this is a bug, due to the following 3 reasons:
 1. ST_3DIntersection(a1, a2) returns POINT Z (0 0 0). So the excepted
 2. Considering the 2D version function, ST_Intersects(a1, a2) returns true
 here:
 SELECT
 FROM ST_GeomFromText('GEOMETRYCOLLECTION(POINT EMPTY, POINT (0 0))') As a1
 --expected{t}
 3. Making the empty point position behind POINT Z (0 0 0),
 ST_3DIntersection(a1, a2) returns true.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5580#comment:6>
