[postgis-tickets] [PostGIS] #5584: PostGIS Upgrade Issue
PostGIS trac at osgeo.org
Fri Oct 20 03:39:29 PDT 2023
  Reporter:  rama                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  critical               |  Milestone:  PostGIS Packaging
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by rama):
 ALTER EXTENSION postgis UPDATE;
 [without version]
 Error Message
 WARNING:  unpackaging raster
 WARNING:  PostGIS Raster functionality has been unpackaged
 HINT:  type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
 After upgrading, if you want to drop raster, run: DROP EXTENSION
 postgis_raster;
 ERROR:  could not load library "R:/Database/11/lib/postgis-3.dll": The
 specified procedure could not be found.
 SQL state: XX000
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5584#comment:5>
