[postgis-tickets] [PostGIS] #5564: BRIN indexes cause server crash after continuous autovacuum
PostGIS trac at osgeo.org
Tue Oct 24 09:21:47 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by robe):
 @giubro,
 Can you confirm you want to work on this, or @pramsey should take the
 reins on this.
 He offered to work on it if you were too busy with other things to work on
 this.
 If you don't respond by the time @pramsey gets back from his conference
 talks and workshop, which I believe will be 2 days from now, then he will
 start working on it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5564#comment:5>
