[postgis-tickets] [PostGIS] #5580: ST_3DIntersects fails when encouting a GEOMETRYCOLLECTION with an empty geometry
PostGIS trac at osgeo.org
Tue Oct 24 10:47:52 PDT 2023
geometry
  Reporter:  Wenjing  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.4.1
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by robe):
 Just a side-note,  ST_3DIntersection is an SFCGAL function.
 ST_3DIntersects is a native.  That is not to say this should not be fixed.
 When there is an empty geometry, many bets are off as to what the right
 answer should be.
 But like I have mentioned before, SFCGAL ships it's own ST_3DIntersects,
 which gives more correct answers than our native ones, but sadly much
 slower. I'm going to open up (or check if we have one already), to expose
 the SFCGAL's ST_3DIntersects as CG_3DIntersects.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5580#comment:9>
