[postgis-tickets] [PostGIS] #5582: Error upgrading data cluster
PostGIS trac at osgeo.org
Tue Oct 24 22:19:21 PDT 2023
  Reporter:  lucadelu               |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by robe):
 Can you give us the output below for your existing postgis install.
 SELECT postgis_full_version(), version()
 I was thinking maybe you had forgotten to run
 SELECT postgis_extensions_upgrade();
 But that function you have in the postgis-3.so complaint is a function
 introduced in 3.4 so should be there in both installs unless somehow your
 PG15 is got an .so for an older version like possibly 3.3.
 What distro are you using for PostGIS?  Could be a bug in the distro
 giving you an older version of PostGIS in PG15
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5582#comment:2>
