[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-708-g252087479
Tue Oct 24 23:23:51 PDT 2023
the project "PostGIS".
       via  2520874793b0fdc65e7b3a41ba5f39ec9b280930 (commit)
      from  83555929fd398344c4a411db69427d41f80a7012 (commit)
revisions in full, below.
commit 2520874793b0fdc65e7b3a41ba5f39ec9b280930
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Wed Oct 25 05:10:45 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5605 of 5605 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 629766801..0e0f9d183 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,8 +6,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-10-06 06:13+0000\n"
-"PO-Revision-Date: 2023-10-25 04:23+0000\n"
-"Last-Translator: Wang Dapeng <wangdapeng20191008 at gmail.com>\n"
+"PO-Revision-Date: 2023-10-25 06:23+0000\n"
+"Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
 "Language: zh_Hans\n"
@@ -6733,16 +6733,16 @@ msgstr ""
 "元素)的拓扑 element_id、element_type。"
 #. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "Returns a set of element_id,element_type (topoelements) corresponding to "
 "primitive topology elements <xref linkend=\"topoelement\"/> (1: nodes, 2: "
 "edges, 3: faces) that a given topogeometry object in <varname>toponame</"
 "varname> schema is composed of."
 msgstr ""
-"返回一组element_id和element_type(topoelements),对应于指定的位于 "
-"<varname>toponame</varname> 模式中的拓扑几何对象所由之原始拓扑元素 <xref "
-"linkend=\"topoelement\"/>(1:节点,2:边,3:面)。"
+"返回一组与基本拓扑元素<xref linkend=\"topoelement\"/>(1:节点,2:边,3:面"
+")对应的element_id、element_type(topoelements),这些元素组成了<varname>topo"
+"name</varname>模式中的给定拓扑几何对象。"
 #. Tag: para
 #, no-c-format
@@ -7078,13 +7078,13 @@ msgstr ""
 "过图层并单独处理这些图层。"
 #. Tag: para
+#, no-c-format
 msgid ""
 "Invoking <filename>pgtopo_export</filename> with the <code>--help</code> (or "
 "<code>-h</code> for short) switch will always print short usage string."
 msgstr ""
-"使用<code>--help </code>(或简称 <code>-h</code>)命令调用 "
-"<filename>pgtopo_export</filename> 将始终打印简短的用法字符串。"
+"调用 <filename>pgtopo_export</filename>时使用 <code>--help</code>(或缩写的 "
+"<code>-h</code>)指令将始终打印简短的用法说明字符串。"
 #. Tag: para
 #, no-c-format
@@ -11970,16 +11970,16 @@ msgid "Tests if a LineString is closed and simple."
 msgstr "检测线串是闭合的还是简单的。"
 #. Tag: para
+#, no-c-format
 msgid ""
 "Returns <varname>TRUE</varname> if this <varname>LINESTRING</varname> is "
 "both <xref linkend=\"ST_IsClosed\"/> (<code>ST_StartPoint(g) ~= "
 "ST_Endpoint(g)</code>) and <xref linkend=\"ST_IsSimple\"/> (does not self "
 "intersect)."
 msgstr ""
-"如果这个 <varname>LINESTRING</varname> 既是 <xref linkend=\"ST_IsClosed\""
-"/>(<code>ST_StartPoint(g) ~= ST_Endpoin(g)</code>)又是 <xref linkend="
-"\"ST_IsSimple\"/>(不自交),则返回 <varname>TRUE</varname>。"
+"返回 <varname>TRUE</varname>,当<varname>LINESTRING</varname> 同时满足 <xref "
+"linkend=\"ST_IsClosed\"/>(即 <code>ST_StartPoint(g) ~= "
+"ST_Endpoint(g)</code>)和 <xref linkend=\"ST_IsSimple\"/>(即不自交)时。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 26 +++++++++++++-------------
 1 file changed, 13 insertions(+), 13 deletions(-)
hooks/post-receive
