[postgis-tickets] [PostGIS] #5588: stable-3.4 branch fails to find docbook XSL
PostGIS trac at osgeo.org
Thu Oct 26 02:21:52 PDT 2023
 Reporter:  strk       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.3.5
Component:  buildbots  |    Version:  3.3.x
 Keywords:             |
 For some reason this is now happenign on stable-3.4:
 > xsl style sheets:
 https://woodie.osgeo.org/repos/30/pipeline/1356/6#L300
 Subsequent build of html fails:
 > https://woodie.osgeo.org/repos/30/pipeline/1356/9#L8
 I'm not sure since when this has been failing because the "docs" workflow
 is only executed when something under doc/ dir changes
 The configure output doesn't show much info about what was tested but
 eventually warns about that:
 > configure: WARNING: could not locate Docbook stylesheets required to
 build the documentation
 https://woodie.osgeo.org/repos/30/pipeline/1356/6#L137
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5588>
