[PostGIS] #5525: Revert change of reliance on pg_file_settings for postgis_topology and postgis_tiger_geocoder
PostGIS trac at osgeo.org
Thu Oct 26 05:38:01 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:  pgextwlist
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"6f0854100a8c290cb26e3bb839c6f0c30742d100/git" 6f08541/git]:
 {{{#!CommitTicketReference repository="git"
 revision="6f0854100a8c290cb26e3bb839c6f0c30742d100"
 Remove duplicated AddToSearchPath implementation
 Use a common one, in new libpgcommon/sql directory.
 References #5525 in 3.4 branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5525#comment:12>
