[SCM] PostGIS branch stable-3.3 updated. 3.3.4-21-gfb96c5174
Thu Oct 26 06:04:18 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  fb96c51744307232166e48d600b6ca9e1fbb7900 (commit)
       via  26dc67c7f6f17ee9f05a23f520ef541ef7c95188 (commit)
       via  8131a1d0b33ce2eb725a45f368bed67a732d8a7c (commit)
       via  f03f601589b3ef6b9b35cf58117f39d5c0710d4e (commit)
      from  bef9d154e2a172e7794000d8a2fbca606d4463d1 (commit)
revisions in full, below.
commit fb96c51744307232166e48d600b6ca9e1fbb7900
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 26 15:03:52 2023 +0200
    Copy run_test.pl from current master branch
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 0ec5b2db0..11d0dabf6 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -16,7 +16,6 @@
 use File::Basename;
 use File::Temp 'tempdir';
 use Time::HiRes qw(time);
-#use File::Which;
 use File::Copy;
 use File::Path;
 use Cwd 'abs_path';
@@ -49,10 +48,21 @@ BEGIN {
 our $DB = $ENV{"POSTGIS_REGRESS_DB"} || "postgis_reg";
-our $REGDIR = abs_path(dirname($0));
-our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"} || ${REGDIR} . '/..';
+our $REGDIR = $ENV{"POSTGIS_REGRESS_DIR"} || abs_path(dirname($0));
+our $TOP_SOURCEDIR = ${REGDIR} . '/..';
+our $ABS_TOP_SOURCEDIR = abs_path(${TOP_SOURCEDIR});
+our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"};
 our $sysdiff = !system("diff --strip-trailing-cr $0 $0 2> /dev/null");
+# Set up some global variables
+my $RUN = 0;
+my $FAIL = 0;
+my $SKIP = 0;
+our $TEST = "";
 # Parse command line opts
@@ -68,7 +78,12 @@ my $OPT_WITH_RASTER = 0;
 my $OPT_WITH_SFCGAL = 0;
 my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
+my $OPT_LEGACY = 0;
 my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_AFTER_RESTORE;
+my @OPT_HOOK_BEFORE_DUMP;
+my @OPT_HOOK_BEFORE_TEST;
+my @OPT_HOOK_AFTER_TEST;
 my @OPT_HOOK_BEFORE_UNINSTALL;
 my @OPT_HOOK_BEFORE_UPGRADE;
 my @OPT_HOOK_AFTER_UPGRADE;
@@ -80,10 +95,10 @@ our $VERBOSE = 0;
 our $OPT_SCHEMA = 'public';
 GetOptions (
-	'verbose' => \$VERBOSE,
+	'verbose+' => \$VERBOSE,
 	'clean' => \$OPT_CLEAN,
 	'nodrop' => \$OPT_NODROP,
-	'upgrade' => \$OPT_UPGRADE,
+	'upgrade+' => \$OPT_UPGRADE,
 	'upgrade-path=s' => \$OPT_UPGRADE_PATH,
 	'dumprestore' => \$OPT_DUMPRESTORE,
 	'nocreate' => \$OPT_NOCREATE,
@@ -93,12 +108,17 @@ GetOptions (
 	'sfcgal' => \$OPT_WITH_SFCGAL,
 	'expect' => \$OPT_EXPECT,
 	'extensions' => \$OPT_EXTENSIONS,
+	'legacy' => \$OPT_LEGACY,
 	'schema=s' => \$OPT_SCHEMA,
 	'build-dir=s' => \$TOP_BUILDDIR,
 	'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
+	'after-test-script=s' => \@OPT_HOOK_AFTER_TEST,
 	'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
+	'before-test-script=s' => \@OPT_HOOK_BEFORE_TEST,
 	'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
-	'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE
+	'before-dump-script=s' => \@OPT_HOOK_BEFORE_DUMP,
+	'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE,
+	'after-restore-script=s' => \@OPT_HOOK_AFTER_RESTORE
 if ( @ARGV < 1 )
@@ -106,13 +126,79 @@ if ( @ARGV < 1 )
 	usage();
-our $SHP2PGSQL = $TOP_BUILDDIR . "/loader/shp2pgsql";
-our $PGSQL2SHP = $TOP_BUILDDIR . "/loader/pgsql2shp";
-our $RASTER2PGSQL = $TOP_BUILDDIR . "/raster/loader/raster2pgsql";
+sub findOrDie
+    my $exec = shift;
+    my $verbose = shift;
+    printf "Checking for %s ... ", $exec if $verbose gt 1;
+    foreach my $d ( split /:/, $ENV{PATH} )
+        my $path = $d . '/' . $exec;
+        if ( -x $path ) {
+            if ( $verbose gt 1 ) {
+                print "found";
+                print " ($path)" if $verbose gt 1;
+                print "\n";
+            return $path
+    print STDERR "Unable to find $exec executable.\n";
+    print STDERR "PATH is " . $ENV{"PATH"} . "\n";
+    die "HINT: use POSTGIS_TOP_BUILD_DIR env or --build-dir switch the specify top build dir.\n";
+# If build dir is not given, try to guess
+if ( "${TOP_BUILDDIR}" eq "" )
+    foreach my $d ( $ENV{'PWD'}, "${TOP_SOURCEDIR}" )
+        if ( -e ${d} . '/postgis_revision.h' )
+            $TOP_BUILDDIR="${d}";
+            last;
+# Prepend scripts' build dirs to path
+# TODO: make this conditional ?
+$ENV{PATH} = $TOP_BUILDDIR . '/loader:' .
+             $TOP_BUILDDIR . '/raster/loader:' .
+             $TOP_BUILDDIR . '/utils:' .
+             $ENV{PATH};
+our $SHP2PGSQL;
+sub shp2pgsql
+    $SHP2PGSQL = findOrDie 'shp2pgsql', @_ unless defined($SHP2PGSQL);
+    return $SHP2PGSQL;
+our $PGSQL2SHP;
+sub pgsql2shp
+    $PGSQL2SHP = findOrDie 'pgsql2shp', @_ unless defined($PGSQL2SHP);
+    return $PGSQL2SHP;
+our $RASTER2PGSQL;
+sub raster2pgsql
+    $RASTER2PGSQL = findOrDie 'raster2pgsql', @_ unless defined($RASTER2PGSQL);
+    return $RASTER2PGSQL;
+our $POSTGIS_RESTORE;
+sub postgis_restore
+    $POSTGIS_RESTORE = findOrDie 'postgis_restore.pl', @_ unless defined($POSTGIS_RESTORE);
 if ( $OPT_UPGRADE_PATH )
-  $OPT_UPGRADE = 1; # implied
+  $OPT_UPGRADE = 1 if not $OPT_UPGRADE; # implied
   my @path = split ('--', $OPT_UPGRADE_PATH);
   $OPT_UPGRADE_FROM = $path[0]
     || die "Malformed upgrade path, <from>--<to> expected, $OPT_UPGRADE_PATH given";
@@ -152,9 +238,6 @@ $PGOPTIONS .= " -c client_min_messages=NOTICE";
 $PGOPTIONS .= " -c extra_float_digits=0";
 $ENV{"PGOPTIONS"} = $PGOPTIONS;
-# Bring the path info in
-my $PATH = $ENV{"PATH"}; # this is useless
 # Calculate the regression directory locations
 my $STAGED_INSTALL_DIR = $TOP_BUILDDIR . "/regress/00-regress-install";
 my $STAGED_SCRIPTS_DIR = $STAGED_INSTALL_DIR . "/share/contrib/postgis";
@@ -163,40 +246,22 @@ my $OBJ_COUNT_PRE = 0;
 my $OBJ_COUNT_POST = 0;
-# Check that we have the executables we need
+# Set up the temporary directory
-print "PATH is $PATH\n";
-foreach my $exec ( ($SHP2PGSQL, $PGSQL2SHP) )
+# Pre-flight to check if we need
+# to find shp2pgsql/pgsql2shp/raster2pgsql
+foreach $TEST (@ARGV)
-	printf "Checking for %s ... ", basename($exec);
-	if ( -x $exec )
-		print "found\n";
-	else
-		print "failed\n";
-		print STDERR "Unable to find $exec executable.\n";
-		print STDERR "TOP_BUILDDIR is ${TOP_BUILDDIR}\n";
-		die "HINT: use POSTGIS_TOP_BUILD_DIR env or --build-dir switch the specify top build dir.\n";
-if ( $OPT_WITH_RASTER )
-	print "Checking for raster2pgsql ... ";
-	if ( -x $RASTER2PGSQL )
-		print "found\n";
-	else
-		print "failed\n";
-		die "Unable to find raster2pgsql executable.\n";
+    if ( -r "${TEST}.dbf" )
+        shp2pgsql($VERBOSE);
+        pgsql2shp($VERBOSE);
+    elsif ( -r "${TEST}.tif" )
+        raster2pgsql($VERBOSE);
@@ -223,7 +288,7 @@ mkpath $TMPDIR; # make sure tmp dir exists
 my $REGRESS_LOG = "${TMPDIR}/regress_log";
 # Report
-print "TMPDIR is $TMPDIR\n";
+print "TMPDIR is $TMPDIR\n" if $VERBOSE gt 1;
 # Prepare the database
@@ -247,6 +312,7 @@ psql -XtAc "
 	WHERE name = 'postgis'
 " template1
+chop $defextver;
 my $dbcount = @dblist;
@@ -279,6 +345,28 @@ else
 my $libver = sql("select postgis_lib_version()");
+sub compute_executor_slow_factor
+    my $ms_to_fetch_full_version = sql(<<EOF
+        CREATE TEMP TABLE _start AS SELECT clock_timestamp() c;
+        SELECT FROM postgis_full_version();
+        SELECT EXTRACT(milliseconds FROM clock_timestamp()-c)
+             FROM _start;
+EOF
+    my $default_ms_to_fetch_full_version = 10;
+    my $test_executor_slow_factor = 1;
+    if ( $ms_to_fetch_full_version gt $default_ms_to_fetch_full_version )
+        $test_executor_slow_factor = $ms_to_fetch_full_version / $default_ms_to_fetch_full_version;
+    print "Executor slow factor: $test_executor_slow_factor ($ms_to_fetch_full_version ms to fetch full version)\n";
+    sql("ALTER DATABASE \\\"$DB\\\" SET test.executor_slow_factor = $test_executor_slow_factor");
+compute_executor_slow_factor;
 if ( ! $libver )
 	`dropdb $DB`;
@@ -287,6 +375,16 @@ if ( ! $libver )
 	exit(1);
+sub staged_scripts_dir
+    unless ( -d $STAGED_SCRIPTS_DIR ) {
+        print STDERR "Unable to find $STAGED_SCRIPTS_DIR directory.\n";
+        print STDERR "TOP_BUILDDIR is $TOP_BUILDDIR.\n";
+    $STAGED_SCRIPTS_DIR;
 sub scriptdir
 	my ( $version, $systemwide ) = @_;
@@ -298,7 +396,7 @@ sub scriptdir
 		chop $scriptdir;
 		$scriptdir .= "/contrib/postgis-" . $pgis_majmin;
 	} else {
-		$scriptdir = $STAGED_SCRIPTS_DIR;
+		$scriptdir = staged_scripts_dir()
 	#print "XXX: scriptdir: $scriptdir\n";
 	return $scriptdir;
@@ -320,40 +418,65 @@ sub semver_lessthan
 	return @bcomp ? 1 : 0;
-if ( $OPT_UPGRADE )
-	print "Upgrading from postgis $libver\n";
-	foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
-		print "Running before-upgrade-script $hook\n";
-		die unless load_sql_file($hook, 1);
-  if ( $OPT_EXTENSIONS )
-    upgrade_spatial_extensions();
-  else
-	  upgrade_spatial();
-	foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
-		print "Running after-upgrade-script $hook\n";
-  # Update libver
-  $libver = sql("select postgis_lib_version()");
 if ( $OPT_DUMPRESTORE )
-  dump_restore();
+    my $DBDUMP = dump_db();
+    die unless defined $DBDUMP;
+    print "Dropping db '${DB}'\n";
+    my $rv = system("dropdb ${DB} >> $REGRESS_LOG 2>&1");
+    if ( $rv ) {
+        fail("Could not drop ${DB}", $REGRESS_LOG);
+        die;
+    print "Creating db '${DB}'\n";
+    $rv = create_db();
+    if ( ! $rv ) {
+        fail("Could not create db ${DB}", $REGRESS_LOG);
+        die;
+    die unless restore_db($DBDUMP);
+    # Update libver
+    $libver = sql("select postgis_lib_version()");
+    unlink($DBDUMP);
+if ( $OPT_UPGRADE )
+    my $upgradesleft = $OPT_UPGRADE;
+    print "Upgrading from postgis $libver ($upgradesleft upgrades requested)\n";
+    foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
+        print "Running before-upgrade-script $hook\n";
+        die unless load_sql_file($hook, 1);
+    while ( $upgradesleft-- )
+        if ( $OPT_EXTENSIONS )
+            die unless upgrade_spatial_extensions();
+        else
+            die unless upgrade_spatial();
+    foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
+        print "Running after-upgrade-script $hook\n";
+    # Update libver
 # Report PostGIS environment
@@ -383,14 +506,6 @@ print "  SFCGAL: $sfcgalver\n" if $sfcgalver;
 print "  GDAL: $gdalver\n" if $gdalver;
-# Set up some global variables
-my $RUN = 0;
-my $FAIL = 0;
-my $SKIP = 0;
-our $TEST = "";
 # Run the tests
@@ -432,6 +547,12 @@ foreach $TEST (@ARGV)
 	# catch a common mistake (strip trailing .sql)
 	$TEST =~ s/.sql$//;
+	foreach my $hook (@OPT_HOOK_BEFORE_TEST)
+		print "  Running before-test-script $hook\n" if $VERBOSE > 1;
 	start_test($TEST);
 	$TEST_OBJ_COUNT_PRE = count_postgis_objects();
@@ -514,6 +635,12 @@ foreach $TEST (@ARGV)
 		fail("PostGIS object count pre-test ($TEST_OBJ_COUNT_POST) != post-test ($TEST_OBJ_COUNT_PRE)");
+	foreach my $hook (@OPT_HOOK_AFTER_TEST)
+		print "  Running after-test-script $hook\n" if $VERBOSE > 1;
 foreach my $hook (@OPT_HOOK_BEFORE_UNINSTALL)
@@ -578,7 +705,8 @@ Usage: $0 [<options>] <testname> [<testname>]
 Options:
   -v, --verbose   be verbose about failures
   --nocreate      do not create the regression database on start
-  --upgrade       source the upgrade scripts on start
+  --upgrade       upgrade db before runnign tests, can be passed
+                  multiple times to perform multiple upgrades.
   --upgrade-path  upgrade path, format <from>--<to>.
                   <from> can be specified as "unpackaged<version>"
                          to specify a script version to start from.
@@ -587,17 +715,19 @@ Options:
                        an exclamation mark (ie: ":auto!" or "3.0.0!") to
                        request upgrade via postgis_extensions_upgrade()
                        if available.
-  --dumprestore   dump and restore spatially-enabled db before running tests
+  --dumprestore   dump and (after upgrade, if --upgrade is given)
+                  restore spatially-enabled db before running tests
   --nodrop        do not drop the regression database on exit
   --schema        where to install/find PostGIS (relocatable) PostGIS
                   (defaults to "public")
   --raster        load also raster extension
-  --tiger      		load also tiger_geocoder extension
+  --tiger         load also tiger_geocoder extension
   --topology      load also topology extension
   --sfcgal        use also sfcgal backend
   --clean         cleanup test logs on exit
   --expect        save obtained output as expected
   --extension     load using extensions
+  --legacy        load also legacy scripts
   --build-dir <path>
                   specify where to find the top build dir of PostGIS,
                   to find binaries and scripts
@@ -607,12 +737,24 @@ Options:
   --before-uninstall-script <path>
                   script to load before spatial extension uninstall
                   (multiple switches supported, to be run in given order)
+  --before-dump-script <path>
+                  script to load before dump, if --dumprestore is given
+                  (multiple switches supported, to be run in given order)
+  --after-restore-script <path>
+                  script to load after restore, if --dumprestore is given
   --before-upgrade-script <path>
                   script to load before upgrade
   --after-upgrade-script <path>
                   script to load after upgrade
+  --before-test-script <path>
+                  script to load before each test run
+  --after-test-script <path>
+                  script to load after each test run
@@ -621,6 +763,12 @@ Options:
 sub start_test
     my $test = shift;
+    my $abstest = abs_path($test);
+    if ( defined($abstest) )
+        $test = $abstest;
+    $test =~ s|${ABS_TOP_SOURCEDIR}/||;
     print " $test ";
 	$RUN++;
     show_progress();
@@ -656,7 +804,7 @@ sub fail
 		printf(" failed (%s)\n", $msg);
-	elsif ( $VERBOSE == 1 )
+	elsif ( $VERBOSE )
 		printf(" failed (%s: %s)\n", $msg, $log);
 		print "-----------------------------------------------------------------------------\n";
@@ -896,7 +1044,7 @@ sub run_loader_and_check_output
 		show_progress();
 		# Produce the output SQL file.
-		$cmd = "$SHP2PGSQL $loader_options -g the_geom ${TEST}.shp $tblname > $outfile 2> $errfile";
+		$cmd = shp2pgsql() . " $loader_options -g the_geom ${TEST}.shp $tblname > $outfile 2> $errfile";
 		$rv = system($cmd);
 		if ( $rv )
@@ -962,7 +1110,7 @@ sub run_dumper_and_check_output
 	if ( $run_always || -r $expected_shp_file )
 		show_progress();
-		$cmd = "${PGSQL2SHP} -f ${TMPDIR}/dumper $DB $tblname > $errfile 2>&1";
+		$cmd = pgsql2shp() . " -f ${TMPDIR}/dumper $DB $tblname > $errfile 2>&1";
 		$rv = system($cmd);
 		if ( $rv )
@@ -1029,7 +1177,7 @@ sub run_raster_loader_and_check_output
 		show_progress();
-		$cmd = "$RASTER2PGSQL $loader_options $raster_file $tblname > $outfile 2> $errfile";
+		$cmd = raster2pgsql() . " $loader_options $raster_file $tblname > $outfile 2> $errfile";
 		$rv = system($cmd);
 		if ( $rv )
@@ -1199,7 +1347,7 @@ sub run_dumper_test
   chomp(@dumplines);
   my $dumpstring = shift @dumplines;
   @dumplines = map { local $_ = $_; s/{regdir}/$REGDIR/; $_ } @dumplines;
-  my @cmd = ("${PGSQL2SHP}", "-f", ${shpfile});
+  my @cmd = ( pgsql2shp(), "-f", ${shpfile});
   push @cmd, @dumplines;
   push @cmd, ${DB};
   push @cmd, $dumpstring;
@@ -1345,7 +1493,7 @@ sub create_db
 		$createcmd .= " --locale=C --locale-provider=libc"
 	$createcmd .= " $DB > $REGRESS_LOG";
-	return system($createcmd);
+	return not system($createcmd);
 sub create_spatial
@@ -1360,14 +1508,14 @@ sub create_spatial
-        prepare_spatial_extensions();
+        exit($FAIL) unless prepare_spatial_extensions();
     else
         if ( ! $OPT_UPGRADE_FROM )
-            prepare_spatial();
-            return;
+            exit($FAIL) unless prepare_spatial();
+            return 1;
         if ( $OPT_UPGRADE_FROM !~ /^unpackaged(.*)/ )
@@ -1379,8 +1527,10 @@ sub create_spatial
             die "--upgrade-path without --extension is only supported with target :auto";
-        prepare_spatial($1);
+        exit($FAIL) unless prepare_spatial($1);
+    return 1;
@@ -1389,18 +1539,13 @@ sub load_sql_file
 	my $file = shift;
 	my $strict = shift;
-	if ( $strict && ! -e $file )
-		fail "Unable to find $file";
-		return 0;
 	if ( -e $file )
 		# ON_ERROR_STOP is used by psql to return non-0 on an error
 		my $psql_opts = "--quiet --no-psqlrc --variable ON_ERROR_STOP=true";
 		my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
 		$cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
+		$cmd .= " -v \"opt_dumprestore=${OPT_DUMPRESTORE}\"";
 		$cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
 		#print "  $file\n" if $VERBOSE;
 		my $rv = system($cmd);
@@ -1411,6 +1556,12 @@ sub load_sql_file
 			return 0;
+	elsif ( $strict )
+		fail "Unable to find $file";
+		return 0;
 	return 1;
@@ -1425,15 +1576,14 @@ sub prepare_spatial_extensions
 	if ( $rv ) {
 	  fail "Error encountered creating target schema ${OPT_SCHEMA}", $REGRESS_LOG;
-	  die;
+	  return 0;
 	my $sql = "CREATE EXTENSION postgis";
 	if ( $OPT_UPGRADE_FROM ) {
 		if ( $OPT_UPGRADE_FROM =~ /^unpackaged(.*)/ ) {
-			return;
+			return prepare_spatial($1);
 		$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
@@ -1445,9 +1595,9 @@ sub prepare_spatial_extensions
 	my $cmd = "psql $psql_opts -c \"". $sql . "\" $DB >> $REGRESS_LOG 2>&1";
-  if ( $rv ) {
-  	fail "Error encountered creating EXTENSION POSTGIS", $REGRESS_LOG;
-  	die;
+    if ( $rv ) {
+        fail "Error encountered creating EXTENSION POSTGIS", $REGRESS_LOG;
+        return 0;
 	if ( $OPT_WITH_TOPO )
@@ -1461,9 +1611,9 @@ sub prepare_spatial_extensions
  		$cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
 		$rv = system($cmd);
-  	if ( $rv ) {
-  		fail "Error encountered creating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
-  		die;
+        if ( $rv ) {
+            fail "Error encountered creating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
+            return 0;
@@ -1478,9 +1628,9 @@ sub prepare_spatial_extensions
 		$rv = system($cmd);
-  	if ( $rv ) {
-  		fail "Error encountered creating EXTENSION POSTGIS_TIGER_GEOCODER", $REGRESS_LOG;
-  		die;
+        if ( $rv ) {
+            fail "Error encountered creating EXTENSION POSTGIS_TIGER_GEOCODER", $REGRESS_LOG;
+            return 0;
@@ -1500,7 +1650,7 @@ sub prepare_spatial_extensions
 		$rv = system($cmd);
 		if ( $rv ) {
 			fail "Error encountered creating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
-			die;
+			return 0;
@@ -1526,7 +1676,7 @@ sub prepare_spatial_extensions
 			$rv = system($cmd);
 			if ( $rv ) {
 				fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
-				die;
+				return 0;
@@ -1544,43 +1694,65 @@ sub prepare_spatial
 	print "Loading PostGIS into '${DB}' \n";
 	# Load postgis.sql into the database
-	load_sql_file("${scriptdir}/postgis.sql", 1);
-	load_sql_file("${scriptdir}/postgis_comments.sql", 0);
-	load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
+	return 0 unless load_sql_file("${scriptdir}/postgis.sql", 1);
+	return 0 unless load_sql_file("${scriptdir}/postgis_comments.sql", 0);
+	return 0 unless load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
+	if ( $OPT_LEGACY )
+		print "Loading legacy.sql from $scriptdir\n";
+		return 0 unless load_sql_file("${scriptdir}/legacy.sql", 0);
 		print "Loading Topology into '${DB}'\n";
-		load_sql_file("${scriptdir}/topology.sql", 1);
-		load_sql_file("${scriptdir}/topology_comments.sql", 0);
+		return 0 unless load_sql_file("${scriptdir}/topology.sql", 1);
+		return 0 unless load_sql_file("${scriptdir}/topology_comments.sql", 0);
 		print "Loading Raster into '${DB}'\n";
-		load_sql_file("${scriptdir}/rtpostgis.sql", 1);
-		load_sql_file("${scriptdir}/raster_comments.sql", 0);
+		return 0 unless load_sql_file("${scriptdir}/rtpostgis.sql", 1);
+		return 0 unless load_sql_file("${scriptdir}/raster_comments.sql", 0);
 	if ( $OPT_WITH_SFCGAL )
 		print "Loading SFCGAL into '${DB}'\n";
-		load_sql_file("${scriptdir}/sfcgal.sql", 1);
-		load_sql_file("${scriptdir}/sfcgal_comments.sql", 0);
+		return 0 unless load_sql_file("${scriptdir}/sfcgal.sql", 1);
+		return 0 unless load_sql_file("${scriptdir}/sfcgal_comments.sql", 0);
 	return 1;
+sub upgrade_extension_sql
+    my ($extname, $from, $to) = @_;
+    my $sql = '';
+    if ( "${libver}" eq "${to}" ) {
+        if ( semver_lessthan($to, "3.3.0") ) {
+            $sql .= "ALTER EXTENSION $extname UPDATE TO '${to}next'; ";
+        } else {
+            $sql .= "ALTER EXTENSION $extname UPDATE TO 'ANY'; ";
+    $sql .= "ALTER EXTENSION $extname UPDATE TO '${to}'";
+    return $sql;
 sub package_extension_sql
 	my ($extname, $extver) = @_;
 	my $sql;
 	if ( $pgvernum lt 130000 ) {
-		$sql = "CREATE EXTENSION ${extname} VERSION '${extver}' FROM unpackaged;";
+		$sql = "CREATE EXTENSION IF NOT EXISTS ${extname} VERSION '${extver}' FROM unpackaged;";
 	} else {
-		$sql = "CREATE EXTENSION ${extname} VERSION unpackaged;";
+		$sql = "CREATE EXTENSION IF NOT EXISTS ${extname} VERSION unpackaged;";
 		$sql .= "ALTER EXTENSION ${extname} UPDATE TO '${extver}'";
 	return $sql;
@@ -1589,31 +1761,34 @@ sub package_extension_sql
 # Upgrade an existing database (soft upgrade)
 sub upgrade_spatial
-    print "Upgrading PostGIS in '${DB}' \n" ;
+    my $version = shift;
+    my $scriptdir = scriptdir($version);
+    print "Upgrading PostGIS in '${DB}' using scripts from $scriptdir\n" ;
     my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
     print "Upgrading core\n";
-    die unless load_sql_file($script, 1);
+    return 0 unless load_sql_file($script, 1);
         $script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
         print "Upgrading topology\n";
         $script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
         print "Upgrading raster\n";
         $script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
         print "Upgrading sfcgal\n";
     return 1;
@@ -1649,19 +1824,20 @@ sub upgrade_spatial_extensions
       $OPT_UPGRADE_TO = $defextver;
-    my $nextver = $OPT_UPGRADE_TO ? "${OPT_UPGRADE_TO}" : "${libver}next";
+    my $nextver = $OPT_UPGRADE_TO ? "${OPT_UPGRADE_TO}" : "${libver}";
     if ( $upgrade_via_function )
-      $sql = "SELECT postgis_extensions_upgrade()";
+        # TODO: pass ${nextver} if supported by OPT_UPGRADE_FROM ?
+        $sql = "SELECT postgis_extensions_upgrade()";
     elsif ( $OPT_UPGRADE_FROM =~ /^unpackaged/ )
-			$sql = package_extension_sql('postgis', ${nextver});
+        $sql = package_extension_sql('postgis', ${nextver});
     else
-      $sql = "ALTER EXTENSION postgis UPDATE TO '${nextver}'";
+        $sql = upgrade_extension_sql('postgis', ${libver}, ${nextver});
     print "Upgrading PostGIS in '${DB}' using: ${sql}\n" ;
@@ -1671,7 +1847,7 @@ sub upgrade_spatial_extensions
     if ( $rv ) {
       fail "Error encountered updating EXTENSION POSTGIS", $REGRESS_LOG;
-      die;
+      return 0;
     # Handle raster split if coming from pre-split extension
@@ -1691,20 +1867,13 @@ sub upgrade_spatial_extensions
       if ( $rv ) {
         fail "Error encountered creating EXTENSION POSTGIS_RASTER from unpackaged on upgrade", $REGRESS_LOG;
-        die;
+        return 0;
       if ( ! $OPT_WITH_RASTER )
-        print "Dropping PostGIS Raster in '${DB}' using: ${sql}\n" ;
-        $sql = "DROP EXTENSION postgis_raster";
-        $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
-        $rv = system($cmd);
-        if ( $rv ) {
-          fail "Error encountered dropping EXTENSION POSTGIS_RASTER on upgrade", $REGRESS_LOG;
-          die;
+        print "Marking PostGIS Raster as present for later drop\n";
+        $OPT_WITH_RASTER=1
@@ -1716,10 +1885,13 @@ sub upgrade_spatial_extensions
     if ( $OPT_WITH_RASTER && has_split_raster_ext(${nextver}) )
-        my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
+        my $sql;
         if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
-					$sql = package_extension_sql('postgis_raster', ${nextver});
+            $sql = package_extension_sql('postgis_raster', ${nextver});
+        else {
+            $sql = upgrade_extension_sql('postgis_raster', ${libver}, ${nextver});
         print "Upgrading PostGIS Raster in '${DB}' using: ${sql}\n" ;
@@ -1728,54 +1900,57 @@ sub upgrade_spatial_extensions
         if ( $rv ) {
           fail "Error encountered updating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
-          die;
+          return 0;
-      my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
+        my $sql;
-			if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
-				$sql = package_extension_sql('postgis_topology', ${nextver});
+        if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
+            $sql = package_extension_sql('postgis_topology', ${nextver});
+        else {
+            $sql = upgrade_extension_sql('postgis_topology', ${libver}, ${nextver});
-      print "Upgrading PostGIS Topology in '${DB}' using: ${sql}\n";
+        print "Upgrading PostGIS Topology in '${DB}' using: ${sql}\n";
-      my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
-      my $rv = system($cmd);
-      if ( $rv ) {
-        fail "Error encountered updating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
-        die;
+        my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+        my $rv = system($cmd);
+        if ( $rv ) {
+            fail "Error encountered updating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
+            return 0;
-			my $sql;
+        my $sql;
-				$sql = package_extension_sql('postgis_sfcgal', ${nextver});
-			elsif ( $OPT_UPGRADE_FROM && semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
-				print "NOTICE: installing SFCGAL extension on upgrade "
-						. "as it was not available in version '$OPT_UPGRADE_FROM'\n";
-				$sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}'";
-			else
-				$sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
+            $sql = package_extension_sql('postgis_sfcgal', ${nextver});
+        elsif ( $OPT_UPGRADE_FROM && semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
+            print "NOTICE: installing SFCGAL extension on upgrade "
+                . "as it was not available in version '$OPT_UPGRADE_FROM'\n";
+            $sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}'";
+        else
+            $sql = upgrade_extension_sql('postgis_sfcgal', ${libver}, ${nextver});
+        $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
-			print "Upgrading PostGIS SFCGAL in '${DB}' using: ${sql}\n" ;
+        print "Upgrading PostGIS SFCGAL in '${DB}' using: ${sql}\n" ;
-      if ( $rv ) {
-        fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
-        die;
+        $rv = system($cmd);
+        if ( $rv ) {
+            fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
+            return 0;
     return 1;
@@ -1797,6 +1972,10 @@ sub drop_spatial
 		load_sql_file("${STAGED_SCRIPTS_DIR}/uninstall_sfcgal.sql");
+		load_sql_file("${STAGED_SCRIPTS_DIR}/uninstall_legacy.sql");
 	load_sql_file("${STAGED_SCRIPTS_DIR}/uninstall_postgis.sql");
   	return 1;
@@ -1806,7 +1985,6 @@ sub drop_spatial_extensions
     my $psql_opts="--no-psqlrc --variable ON_ERROR_STOP=true";
-    my $ok = 1;
     my ($cmd, $rv);
@@ -1816,21 +1994,30 @@ sub drop_spatial_extensions
         #       http://trac.osgeo.org/postgis/ticket/2138
         $cmd = "psql $psql_opts -c \"DROP EXTENSION postgis_topology; DROP SCHEMA topology;\" $DB >> $REGRESS_LOG 2>&1";
         $rv = system($cmd);
-      	$ok = 0 if $rv;
+        if ( $rv ) {
+            fail "Error encountered dropping EXTENSION postgis_topology", $REGRESS_LOG;
+            return 0;
         $cmd = "psql $psql_opts -c \"DROP EXTENSION postgis_sfcgal;\" $DB >> $REGRESS_LOG 2>&1";
         $rv = system($cmd);
-        $ok = 0 if $rv;
+        if ( $rv ) {
+            fail "Error encountered dropping EXTENSION postgis_sfcgal", $REGRESS_LOG;
+            return 0;
         $cmd = "psql $psql_opts -c \"DROP EXTENSION IF EXISTS postgis_raster;\" $DB >> $REGRESS_LOG 2>&1";
         $rv = system($cmd);
-      	$ok = 0 if $rv;
+        if ( $rv ) {
+            fail "Error encountered dropping EXTENSION postgis_raster", $REGRESS_LOG;
+            return 0;
     if ( $OPT_WITH_TIGER )
@@ -1840,17 +2027,21 @@ sub drop_spatial_extensions
                 DROP SCHEMA IF EXISTS tiger_data;
         $rv = system($cmd);
-      	$ok = 0 if $rv;
+      	return 0 if $rv;
+        if ( $rv ) {
+            fail "Error encountered dropping EXTENSION postgis_tiger_geocoder", $REGRESS_LOG;
+            return 0;
     $cmd = "psql $psql_opts -c \"DROP EXTENSION postgis\" $DB >> $REGRESS_LOG 2>&1";
     $rv = system($cmd);
     if ( $rv ) {
         fail "Error encountered dropping EXTENSION POSTGIS", $REGRESS_LOG;
-        die;
+      	return 0;
-    return $ok;
+    return 1;
 # Drop spatial from an existing database
@@ -1877,6 +2068,29 @@ sub uninstall_spatial
 	if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
 		fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
+        if ( $OPT_UPGRADE_FROM )
+            my $fromversion = $OPT_UPGRADE_FROM;
+            $fromversion =~ s/unpackaged//;
+            print
+                "\n-------------------------------------------------\n",
+                "Need to add these to an after_upgrade.sql script?",
+                sql("
+SELECT format(
+    'SELECT _postgis_drop_function_by_identity(%L, %L, %L);',
+    proname,
+    pg_catalog.pg_get_function_identity_arguments(oid),
+    '$fromversion'
+FROM pg_proc
+WHERE pronamespace = '${OPT_SCHEMA}'::regnamespace
+ORDER BY 1;
 		return 0;
@@ -1884,56 +2098,82 @@ sub uninstall_spatial
 	return 1;
-# Dump and restore the database
-sub dump_restore
+# Dump the database, return dump filename
+sub dump_db
-  my $DBDUMP = $TMPDIR . '/' . $DB . ".dump";
-  my $rv;
+    my $rv;
+    my $DBDUMP = $TMPDIR . '/' . $DB . '.dump';
-	print "Dumping and restoring database '${DB}'\n";
-  $rv = system("pg_dump -Fc -f${DBDUMP} ${DB} >> $REGRESS_LOG 2>&1");
-  if ( $rv ) {
-    fail("Could not dump ${DB}", $REGRESS_LOG);
-		die;
-  $rv = system("dropdb ${DB} >> $REGRESS_LOG 2>&1");
-  if ( $rv ) {
-    fail("Could not drop ${DB}", $REGRESS_LOG);
-		die;
-  $rv = create_db();
-  if ( $rv ) {
-    fail("Could not create ${DB}", $REGRESS_LOG);
-		die;
-  $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
-  if ( $rv ) {
-    fail("Could not restore ${DB}", $REGRESS_LOG);
-    die;
-  if ( $OPT_WITH_TOPO )
-    # We need to re-add "topology" to the search_path as it is lost
-    # on dump/reload, see https://trac.osgeo.org/postgis/ticket/3454
-    my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
-    my $cmd = "psql $psql_opts -c \"SELECT topology.AddToSearchPath('topology')\" $DB >> $REGRESS_LOG 2>&1";
-    if ( $rv ) {
-      fail("Error encountered adding topology to search path after restore", $REGRESS_LOG);
-      die;
+    foreach my $hook (@OPT_HOOK_BEFORE_DUMP)
+        print "Running before-dump-script $hook\n";
-  unlink($DBDUMP);
+    print "Dumping database '${DB}'\n";
-  return 1;
+    $rv = system("pg_dump -Fc -f${DBDUMP} ${DB} >> $REGRESS_LOG 2>&1");
+    if ( $rv ) {
+        fail("Could not dump ${DB}", $REGRESS_LOG);
+        return undef;
+    return ${DBDUMP};
+# Restore the dump file passed as first argument
+sub restore_db
+    my $rv;
+    my $DBDUMP = shift;
+    my $ext_dump = $OPT_EXTENSIONS && $OPT_UPGRADE_FROM !~ /^unpackaged/;
+    # If dump is not from extension-based database
+    # we need to prepare the target
+    unless ( $ext_dump )
+		if ( $OPT_UPGRADE_FROM =~ /^unpackaged(.*)/ ) {
+			die unless prepare_spatial($1);
+		} else {
+			die unless prepare_spatial();
+    if ( $ext_dump ) {
+        print "Restoring database '${DB}' using pg_restore\n";
+        $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
+    } else {
+        print "Restoring database '${DB}' using postgis_restore.pl\n";
+        my $cmd = postgis_restore() . " ${DBDUMP} | psql --set ON_ERROR_STOP=1 -X ${DB} >> $REGRESS_LOG 2>&1";
+    if ( $rv ) {
+        fail("Could not restore ${DB}", $REGRESS_LOG);
+        return 0;
+    if ( $OPT_WITH_TOPO )
+        # We need to re-add "topology" to the search_path as it is lost
+        # on dump/reload, see https://trac.osgeo.org/postgis/ticket/3454
+        my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
+        my $cmd = "psql $psql_opts -c \"SELECT topology.AddToSearchPath('topology')\" $DB >> $REGRESS_LOG 2>&1";
+        if ( $rv ) {
+            fail("Error encountered adding topology to search path after restore", $REGRESS_LOG);
+            return 0;
+    foreach my $hook (@OPT_HOOK_AFTER_RESTORE)
+        print "Running after-restore-script $hook\n";
+    return 1;
+# Dump and restore the database
 sub diff
 	my ($expected_file, $obtained_file) = @_;
commit 26dc67c7f6f17ee9f05a23f520ef541ef7c95188
Date:   Fri May 5 16:16:27 2023 +0200
    Tolerate 250ms elapsed time for ST_Buffer interruption
    Hopefully works on more bots
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index c0d6a4fb5..77290e0d2 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -35,7 +35,7 @@ SET statement_timeout TO 100;
 select ST_Buffer(g,100) from _inputs WHERE id = 1;
 --( select (st_dumppoints(st_buffer(st_makepoint(0,0),10000,100000))).geom g) foo;
 -- it may take some more to interrupt st_buffer, see
-SELECT _timecheck('buffer', '200ms');
+SELECT _timecheck('buffer', '250ms');
 -- Not affected by old timeout
 SELECT '1', ST_NPoints(ST_Buffer('POINT(4 0)'::geometry, 2, 1));
commit 8131a1d0b33ce2eb725a45f368bed67a732d8a7c
Date:   Thu Oct 26 10:45:56 2023 +0200
    Remove duplicated AddToSearchPath implementation
    Use a common one, in new libpgcommon/sql directory.
    References #5525 in 3.3 branch
diff --git a/.gitignore b/.gitignore
index b71e14cda..2f02ecfd6 100644
--- a/.gitignore
+++ b/.gitignore
@@ -44,6 +44,7 @@ doc/raster_gardentest_*.sql
 doc/tiger_geocoder_comments.sql
 doc/topology_comments.sql
 extensions/Makefile
+extensions/postgis_extension_helper.sql
 extensions/address_standardizer/Makefile
 extensions/address_standardizer/mk-st-regexp
 extensions/address_standardizer/address_standardizer--*.sql
diff --git a/extensions/Makefile.in b/extensions/Makefile.in
index 0c48b615e..e984e4b06 100644
--- a/extensions/Makefile.in
+++ b/extensions/Makefile.in
@@ -9,6 +9,13 @@
+srcdir = @srcdir@
+SQLPP = @SQLPP@
+PERL=@PERL@
+VPATH := $(srcdir)
+SCRIPTS_BUILT = postgis_extension_helper.sql
 SUBDIRS = postgis
 SUBDIRS += postgis_tiger_geocoder
 ifeq (@RASTER@,raster)
@@ -31,12 +38,23 @@ all clean distclean install uninstall installcheck:
 		$(MAKE) -C "$${DIR}" $@ || exit 1; \
 	done
+all: $(SCRIPTS_BUILT)
 distclean: distclean-local
 distclean-local:
 	rm -f Makefile
 check check-unit check-regress:
 	@echo "Nothing to check"
+# Generate any .sql file from .sql.in files by running them through the SQL pre-processor
+%.sql: %.sql.in
+	$(SQLPP) -I at top_builddir@/postgis -I at top_srcdir@ $< > $@.tmp
+	grep -v '^#' $@.tmp > $@;
+	rm -f $@.tmp
+clean: clean-local
+clean-local:
+	rm -f $(SCRIPTS_BUILT)
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql.in
similarity index 75%
rename from extensions/postgis_extension_helper.sql
rename to extensions/postgis_extension_helper.sql.in
index a984ecb92..632385133 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql.in
@@ -102,60 +102,4 @@ $$
 LANGUAGE plpgsql VOLATILE;
 CREATE FUNCTION postgis_extension_AddToSearchPath(a_schema_name text)
-RETURNS text
-AS
-DECLARE
-	var_result text;
-	var_cur_search_path text;
-BEGIN
-	WITH settings AS (
-		SELECT pg_catalog.unnest(setconfig) config
-		FROM pg_catalog.pg_db_role_setting
-		WHERE setdatabase OPERATOR(pg_catalog.=) (
-			SELECT oid
-			FROM pg_catalog.pg_database
-			WHERE datname OPERATOR(pg_catalog.=) pg_catalog.current_database()
-		) and setrole OPERATOR(pg_catalog.=) 0
-	SELECT pg_catalog.regexp_replace(config, '^search_path=', '')
-	FROM settings WHERE config like 'search_path=%'
-	INTO var_cur_search_path;
-	RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
-	IF var_cur_search_path IS NULL THEN
-		SELECT setting
-		FROM pg_catalog.pg_file_settings
-		WHERE name OPERATOR(pg_catalog.=) 'search_path' AND applied;
-		RAISE NOTICE 'cur_search_path from pg_file_settings is %', var_cur_search_path;
-	END IF;
-		SELECT boot_val
-		FROM pg_catalog.pg_settings
-		WHERE name OPERATOR(pg_catalog.=) 'search_path';
-		RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
-	END IF;
-	IF var_cur_search_path LIKE '%' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name) OPERATOR(pg_catalog.||) '%' THEN
-		var_result := a_schema_name OPERATOR(pg_catalog.||) ' already in database search_path';
-	ELSE
-		var_cur_search_path := var_cur_search_path OPERATOR(pg_catalog.||) ', '
-                       OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name);
-		EXECUTE 'ALTER DATABASE ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(pg_catalog.current_database())
-                             OPERATOR(pg_catalog.||) ' SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
-		var_result := a_schema_name OPERATOR(pg_catalog.||) ' has been added to end of database search_path ';
-	END IF;
-	EXECUTE 'SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
-  RETURN var_result;
-END
-LANGUAGE 'plpgsql' VOLATILE STRICT;
+#include "libpgcommon/sql/AddToSearchPath.sql.inc"
diff --git a/topology/sql/manage/ManageHelper.sql.in b/libpgcommon/sql/AddToSearchPath.sql.inc
similarity index 72%
copy from topology/sql/manage/ManageHelper.sql.in
copy to libpgcommon/sql/AddToSearchPath.sql.inc
index eb9da2d02..2499bfa91 100644
--- a/topology/sql/manage/ManageHelper.sql.in
+++ b/libpgcommon/sql/AddToSearchPath.sql.inc
@@ -1,29 +1,18 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://www.postgis.net
--- Copyright (C) 2011 Regina Obe <lr at pcorp.us>
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
---  AddToSearchPath(schema_name)
--- Adds the specified schema to the database search path
--- if it is not already in the database search path
--- This is a helper function for upgrade/install
--- We may want to move this function as a generic helper
-CREATE OR REPLACE FUNCTION topology.AddToSearchPath(a_schema_name varchar)
+  Common body for a function to add a schema to the search path
+  Use as follows:
+    CREATE OR REPLACE FUNCTION someName(someARg text)
+    #include "libpgcommon/sql/AddToSearchPath.sql.inc"
 RETURNS text
 AS
+$BODY$
 DECLARE
 	var_result text;
+	a_schema_name text := $1;
 BEGIN
 	WITH settings AS (
@@ -72,7 +61,6 @@ BEGIN
   RETURN var_result;
 END
+$BODY$
---} AddToSearchPath
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 6bd085fe3..6270b701f 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -104,7 +104,7 @@ endif
 %.sql: %.sql.in
-	$(SQLPP) -I at top_builddir@/postgis $< | grep -v '^#' | \
+	$(SQLPP) -I at top_builddir@/postgis -I at top_srcdir@ $< | grep -v '^#' | \
 	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
 #Generate upgrade script by stripping things that can't be reinstalled
diff --git a/topology/sql/manage/ManageHelper.sql.in b/topology/sql/manage/ManageHelper.sql.in
index eb9da2d02..4c912317b 100644
+++ b/topology/sql/manage/ManageHelper.sql.in
@@ -18,61 +18,5 @@
-RETURNS text
-AS
-DECLARE
-	var_result text;
-BEGIN
-			SELECT oid
-		SELECT setting
-	END IF;
-		SELECT boot_val
-	END IF;
-	ELSE
-	END IF;
-END
 --} AddToSearchPath
commit f03f601589b3ef6b9b35cf58117f39d5c0710d4e
Date:   Thu Oct 26 14:44:50 2023 +0200
    [woodie] Share clone step for regress workflow
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index aa4d55983..167670125 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -1,14 +1,39 @@
-matrix:
-  PG_VERSION:
-    - 15
-    - 14
-    - 12
-    - 11
+variables:
+  test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel3
+clone:
+  clone:
+    image: woodpeckerci/plugin-git
+    depth: 50
 steps:
-  build:
-    group: build
-    image: docker.osgeo.org/postgis/build-test:trisquel3
+  autogen:
+    image: *test-image
+    pull: true
     commands:
-      - sh autogen.sh
-      - PGVER=${PG_VERSION} sh ci/dronie/postgis_regress.sh
+      - ./autogen.sh
+  regress-pg11:
+    group: build
+    commands:
+      - PGVER=11 sh ci/dronie/postgis_regress.sh
+  regress-pg12:
+    group: build
+    commands:
+      - PGVER=12 sh ci/dronie/postgis_regress.sh
+  regress-pg14:
+    group: build
+    commands:
+      - PGVER=15 sh ci/dronie/postgis_regress.sh
+  regress-pg15:
+    group: build
+    commands:
Summary of changes:
 .gitignore                                         |   1 +
 .woodpecker/regress.yml                            |  45 +-
 extensions/Makefile.in                             |  20 +-
 ..._helper.sql => postgis_extension_helper.sql.in} |  58 +-
 .../sql/AddToSearchPath.sql.inc                    |  32 +-
 regress/core/interrupt_buffer.sql                  |   2 +-
 regress/run_test.pl                                | 684 ++++++++++++++-------
 topology/Makefile.in                               |   2 +-
 topology/sql/manage/ManageHelper.sql.in            |  58 +-
 9 files changed, 531 insertions(+), 371 deletions(-)
 rename extensions/{postgis_extension_helper.sql => postgis_extension_helper.sql.in} (75%)
 copy topology/sql/manage/ManageHelper.sql.in => libpgcommon/sql/AddToSearchPath.sql.inc (72%)
hooks/post-receive
