[PostGIS] #5525: Revert change of reliance on pg_file_settings for postgis_topology and postgis_tiger_geocoder
PostGIS trac at osgeo.org
Thu Oct 26 06:31:19 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:  pgextwlist
Comment (by strk):
 Now the de-duplication is in place, as far as into 3.3 branch - we can fix
 first and then see how to move forward.
 The referenced breaking change moved from using pg_settings to use
 pg_file_settings, what was the rationale for that ?
 Was the querying of pg_settings safe under pgextwlist ?
 Should we postpone the fix to after our CI can run under pgextwlist ? See
 #5566
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5525#comment:14>
