[SCM] PostGIS branch master updated. 3.4.0rc1-712-g023b13918
Thu Oct 26 09:50:13 PDT 2023
the project "PostGIS".
       via  023b13918c3554915047b13869236d7e44b7dfc3 (commit)
      from  fdd2fa156509b11e7318474981b2187d50abeae3 (commit)
revisions in full, below.
commit 023b13918c3554915047b13869236d7e44b7dfc3
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 26 18:49:28 2023 +0200
    Fix script-based load of topology by qualifying refs to TopoGeometry
    References #5590 in master branch (3.5.0dev)
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index b1d5969dd..97c0e3926 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1300,7 +1300,7 @@ AS  $$SELECT ARRAY[topo.id,topo.layer_id]::topology.topoelement;$$;
 -- Availability: 3.4.0
-CREATE CAST (topogeometry AS int[]) WITH FUNCTION TopoElement(topogeometry) AS ASSIGNMENT;
+CREATE CAST (topology.TopoGeometry AS int[]) WITH FUNCTION topology.TopoElement(topology.TopoGeometry) AS ASSIGNMENT;
 --} TopoGeometry(int[])
Summary of changes:
 topology/topology.sql.in | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
