[PostGIS] #5525: ERROR: permission denied for view pg_file_settings
PostGIS trac at osgeo.org
Thu Oct 26 10:02:08 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:  pgextwlist
Comment (by strk):
 The original problem description is in #5442 which reports 2 problems:
   1. Changing boot value based on current value rather than bool value
   2. Changing session value based on boot val rather than current val
 Jeff is my understanding of the problem correct ?
 Regina: would there be any problem to set per-function search_path rather
 than fully qualified all those pg_catalog calls ? That hurts my eyes :)
 My proposed solution for that is in
 https://git.osgeo.org/gitea/postgis/postgis/pulls/161
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5525#comment:16>
