[PostGIS] #5212: Can't regress test PostGIS using non-superuser PostgreSQL role (cannot set lc_messages)
PostGIS trac at osgeo.org
Fri Oct 27 01:47:34 PDT 2023
lc_messages)
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.5.0
 Component:  build/upgrade/install  |    Version:  3.0.x
Resolution:                         |   Keywords:  pgextwlist
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"5739cacd977d4917805a4485fa5f6b38dfce4d9a/git"
 5739cacd/git]:
 {{{#!CommitTicketReference repository="git"
 revision="5739cacd977d4917805a4485fa5f6b38dfce4d9a"
 run_test.pl: add POSTGIS_REGRESS_DB_OWNER env support
 Allows specifying a DB role to be given ownership of the regress
 database and be used to create extension of POSTGIS_REGRESS_EXT_CREATOR
 is not also provided to override that.
 References #5212
 References #5566
 References #5567
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5212#comment:9>
