[SCM] PostGIS branch master updated. 3.4.0rc1-718-g120359068
Fri Oct 27 03:52:49 PDT 2023
the project "PostGIS".
       via  12035906869dd35d6906718b600402e15d36f843 (commit)
       via  b2ee709135c88ef3dea5b1b3abc729457d593d4b (commit)
      from  5739cacd977d4917805a4485fa5f6b38dfce4d9a (commit)
revisions in full, below.
commit 12035906869dd35d6906718b600402e15d36f843
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Oct 27 12:49:39 2023 +0200
    ci/dronie/postgis_regress.sh: do not override RUNTESTFLAGS
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 32becff59..f358c11ac 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -8,6 +8,11 @@ export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{pr
 export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
 psql --version
+# Make test runs verbose
+export RUNTESTFLAGS="$RUNTESTFLAGS -v"
 # Out of tree build for given PostgreSQL version
@@ -28,9 +33,9 @@ psql -c "select version()" template1
 # Pre-install tests
-RUNTESTFLAGS=-v make check
-RUNTESTFLAGS=-v make check-double-upgrade
-RUNTESTFLAGS=-v make check-locked-upgrade
+make check
+make check-double-upgrade
+make check-locked-upgrade
 # Install
@@ -42,7 +47,7 @@ make install
 # Post-install tests
-RUNTESTFLAGS=-v make installcheck
+make installcheck
 # Upgrade tests
commit b2ee709135c88ef3dea5b1b3abc729457d593d4b
Date:   Fri Oct 27 11:38:58 2023 +0200
    run_test.pl: add --after-create-db-script support
    This can be used to configure target database, for example to
    enable/configure pgextwlist
    References #5566
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 1b7f47a44..5fa78b212 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -83,6 +83,7 @@ my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
 my $OPT_LEGACY = 0;
 my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_AFTER_CREATE_DB;
 my @OPT_HOOK_AFTER_RESTORE;
 my @OPT_HOOK_BEFORE_DUMP;
 my @OPT_HOOK_BEFORE_TEST;
@@ -115,6 +116,7 @@ GetOptions (
 	'schema=s' => \$OPT_SCHEMA,
 	'build-dir=s' => \$TOP_BUILDDIR,
 	'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
+	'after-create-db-script=s' => \@OPT_HOOK_AFTER_CREATE_DB,
 	'after-test-script=s' => \@OPT_HOOK_AFTER_TEST,
 	'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
 	'before-test-script=s' => \@OPT_HOOK_BEFORE_TEST,
@@ -737,6 +739,9 @@ Options:
   --after-create-script <path>
                   script to load after spatial db creation
                   (multiple switches supported, to be run in given order)
+  --after-create-db-script <path>
+                  script to load after db creation
+                  (multiple switches supported, to be run in given order)
   --before-uninstall-script <path>
                   script to load before spatial extension uninstall
@@ -1514,7 +1519,14 @@ sub create_db
 		$createcmd .= " --owner $DB_OWNER";
 	$createcmd .= " $DB > $REGRESS_LOG";
-	return not system($createcmd);
+	return 0 if system($createcmd);
+	foreach my $hook (@OPT_HOOK_AFTER_CREATE_DB)
+		print "Running after-create-db-script $hook\n";
+		die unless load_sql_file($hook, 1);
 sub create_spatial
Summary of changes:
 ci/dronie/postgis_regress.sh | 13 +++++++++----
 regress/run_test.pl          | 14 +++++++++++++-
 2 files changed, 22 insertions(+), 5 deletions(-)
hooks/post-receive
