[PostGIS] #5566: Add CI testing under sandboxed system
PostGIS trac at osgeo.org
Fri Oct 27 03:52:54 PDT 2023
  Reporter:  strk          |      Owner:  robe
      Type:  task          |     Status:  new
  Priority:  medium        |  Milestone:  Website Management, Bots
 Component:  QA/buildbots  |    Version:
Resolution:                |   Keywords:  pgextwlist
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"b2ee709135c88ef3dea5b1b3abc729457d593d4b/git" b2ee709/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b2ee709135c88ef3dea5b1b3abc729457d593d4b"
 run_test.pl: add --after-create-db-script support
 This can be used to configure target database, for example to
 enable/configure pgextwlist
 References #5566
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5566#comment:6>
