[PostGIS] #5584: PostGIS Upgrade Issue
PostGIS trac at osgeo.org
Fri Oct 27 04:39:24 PDT 2023
  Reporter:  rama                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  critical               |  Milestone:  PostGIS Packaging
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:  windows
Comment (by rama):
 As recommended I have updated the PostgreSQL version to 11.21
 The good news is that Postgis is upgraded to 3.3.3!! But Postgis_raster
 doesn't exist in the extension list
  But facing issues with raster, sfcgal, and pgrouting Could you please
 suggest what could we do for the same
 ALTER EXTENSION postgis UPDATE TO "3.3.3";
 WARNING:  unpackaging raster
 WARNING:  PostGIS Raster functionality has been unpackaged
 HINT:  type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
 After upgrading, if you want to drop raster, run: DROP EXTENSION
 postgis_raster;
 ALTER EXTENSION
 NOTICE:  Updating extension postgis 3.3.3
 NOTICE:  Updating extension postgis_sfcgal 2.5.0
 ERROR:  aggregate st_3dunion(geometry) does not exist
 CONTEXT:  SQL statement "UPDATE pg_catalog.pg_extension SET extversion =
 'ANY' WHERE extname = 'postgis_sfcgal';ALTER EXTENSION postgis_sfcgal
 UPDATE TO "3.3.3""
 PL/pgSQL function postgis_extensions_upgrade() line 104 at EXECUTE
 UPDATE TO "3.3.3""
 When I try to upgrade pgrouting and  postgis_sfcgal extension i get an
 Error
 ##postgis_sfcgal
 ALTER EXTENSION postgis_sfcgal UPDATE TO "3.3.3";
 ##pgrouting
 ALTER EXTENSION pgrouting UPDATE TO "3.5.0";
 ERROR:  function pgr_dijkstra(text, bigint, anyarray, boolean) does not
 exist
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5584#comment:12>
